Home > Maintenance & Mods (L322) > Loosing the will to live, |
wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64 |
Is the thermostat operating? Is the system clean?
7th Jun 2013 4:24pm |
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 195 |
I am no expert in these, I spend my time usually in the Disco3 Forum where I am in my comfort zone, but I notice that the water pump fitted to your engine was a common BMW water pump and many of these suffered from the impellor coming loose and so not pumping properly, could this be your issue? Paul Redding
7th Jun 2013 4:44pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Hello and welcome... Bit harsh calling yourself a dizzy bint !
7th Jun 2013 4:57pm |
Jordanschroeder Member Since: 07 Jun 2013 Location: Redditch worcestershire Posts: 3 |
Sensors checked the mechanic said it was ok but I think he just likes the colour of my cheque book! Dizzybint |
7th Jun 2013 5:03pm |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 |
No sensor on the water pump AFAIK. Got to be worth a look. Graham
7th Jun 2013 5:05pm |
Yup got it in one car is great on long runs just mega pants in traffic, I'm off to Bordeaux in it in August, well I say I am!!!, Dizzybint |
New Thermostat is only £65..... (Easy fit as well) |
7th Jun 2013 5:09pm |
No idea how far you are from Cam Tech Craig and if you are too far away, I suggest to ask the forum for a reliable mechanic in your area. To me it sounds like your technician thinks Range Rover so they must be loaded (how wrong they are, the money pours out faster than with a bloody superyacht turning us into instant paupers with a nice car).
7th Jun 2013 5:11pm |
We supply Thermostat @ £46.38 Water Pump @ £39.20 both German products oddly enough Paul Redding
7th Jun 2013 5:14pm |
If you connect the vehicle to Testbook and look at the live data, the engine ECU will only open the thermostat at around 105C. This is to keep the engine as hot as possible to keep the emissions as low as possible. If the thermostat doesn't open properly, then it cannot drop the engine temperature because it cannot use the radiator.
7th Jun 2013 5:57pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34945 |
what would the postage be on these Steve? ... - .- -. click link for , FORUM WIKI HOW TO Ǝꓕ∀ꓕOꓤ PICS workshop manual downloads are in our wiki . |
7th Jun 2013 6:00pm |
Or the old fashioned way... Take out the thermostat, drop it in a mug of boiling water and see if it moves.. Probably better doing it the high tech way though! Previously..
7th Jun 2013 6:02pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
If you have had fluid changed have they got all the air out properly? Use the hidden menu in he dash to get a numerical number on how hot she's getting. You can also mod the electric thermostat to be open perminantly that will reduce the overall temp by about 7-10deg. Obviously will mean it takes longer to heat up in winter etc. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
7th Jun 2013 6:08pm |
£6.50 courier Stan Paul Redding
7th Jun 2013 7:15pm |
