![]() | Home > Maintenance & Mods (L322) > Loosing the will to live, |
| wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64
Is the thermostat operating? Is the system clean?
| Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 198
I am no expert in these, I spend my time usually in the Disco3 Forum where I am in my comfort zone, but I notice that the water pump fitted to your engine was a common BMW water pump and many of these suffered from the impellor coming loose and so not pumping properly, could this be your issue? Paul Redding
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Hello and welcome... Bit harsh calling yourself a dizzy bint ! |
| Jordanschroeder Member Since: 07 Jun 2013 Location: Redditch worcestershire Posts: 3
Sensors checked the mechanic said it was ok but I think he just likes the colour of my cheque book! Dizzybint |
| A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973
No sensor on the water pump AFAIK. Got to be worth a look. Graham
Yup got it in one car is great on long runs just mega pants in traffic, I'm off to Bordeaux in it in August, well I say I am!!!, Dizzybint |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
New Thermostat is only £65..... (Easy fit as well) |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
No idea how far you are from Cam Tech Craig and if you are too far away, I suggest to ask the forum for a reliable mechanic in your area. To me it sounds like your technician thinks Range Rover so they must be loaded (how wrong they are, the money pours out faster than with a bloody superyacht turning us into instant paupers with a nice car).
We supply Thermostat @ £46.38 Water Pump @ £39.20 both German products oddly enough Paul Redding
If you connect the vehicle to Testbook and look at the live data, the engine ECU will only open the thermostat at around 105C. This is to keep the engine as hot as possible to keep the emissions as low as possible. If the thermostat doesn't open properly, then it cannot drop the engine temperature because it cannot use the radiator.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
what would the postage be on these Steve? ... - .- -. Y. O. L. O. . |
Or the old fashioned way... Take out the thermostat, drop it in a mug of boiling water and see if it moves.. Probably better doing it the high tech way though! Previously..
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
If you have had fluid changed have they got all the air out properly? Use the hidden menu in he dash to get a numerical number on how hot she's getting. You can also mod the electric thermostat to be open perminantly that will reduce the overall temp by about 7-10deg. Obviously will mean it takes longer to heat up in winter etc. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
£6.50 courier Stan Paul Redding
| All times are GMT |
