Home > Technical (L322) > How do you adjust the tailgate lower door alignment? |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
My tailgate lower door has dropped slightly and I'd like to realign it as it's bugging me every time I look at the rear of my car. It's only 2 or 3 mm but enough to annoy when I can see the gap between the upper and lower doors is slightly bigger on the left than on the right.
30th Jun 2013 8:33pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16180 |
Post up some pics Baron so i can check its not somthing different... |
30th Jun 2013 8:37pm |
First pic is the right which is aligned okay.
30th Jun 2013 9:17pm |
I believe you can adjust it up and down on the hinge bolts behind the carpeted cover...
30th Jun 2013 11:42pm |
That's what I'm hoping but not clear which bolts to adjust, e.g is there an actual "adjusting bolt" or is it just a couple of bolts and a bracket/hinge? 4.4 TDV8 Vogue Baltic Blue MY11 |
1st Jul 2013 12:25am |
I will look at one of ours in the morning and PM you sir |
1st Jul 2013 1:32am |
Thanks Craig 4.4 TDV8 Vogue Baltic Blue MY11 |
1st Jul 2013 8:51am |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Can you post the answer on here please Craig as mines a bit wonky too.
1st Jul 2013 12:58pm |
