![]() | Home > Technical (L322) > How do you adjust the tailgate lower door alignment? |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
My tailgate lower door has dropped slightly and I'd like to realign it as it's bugging me every time I look at the rear of my car. It's only 2 or 3 mm but enough to annoy when I can see the gap between the upper and lower doors is slightly bigger on the left than on the right.
Post up some pics Baron so i can check its not somthing different... |
First pic is the right which is aligned okay.
I believe you can adjust it up and down on the hinge bolts behind the carpeted cover...
That's what I'm hoping but not clear which bolts to adjust, e.g is there an actual "adjusting bolt" or is it just a couple of bolts and a bracket/hinge? Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
I will look at one of ours in the morning and PM you sir |
Thanks Craig Current: Volvo XC40 T4 R-Design. Loitering with intent to possibly buy back in.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Can you post the answer on here please Craig as mines a bit wonky too. |
