![]() | Home > Maintenance & Mods (L322) > door cappings |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Yes Andy you need to take the door panels off and there is a 10mm nut on each end inside the panel |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 972 ![]() ![]() ![]() |
cheers craig, am guessing its just clips to get he door cards off?
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 ![]() ![]() ![]() |
Two torx screws along the door pocket and one in the door handle and a 10mm nut behind the Landrover badge and then it unclips.
ok so have done the door storage cappings which was straight foward and i have some door surrounds to put on (the powerfuluk sticky on ones) but i havent got any of the window switches yet, as am not sure whether to go stick on route or actual proper part...... so two q's
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I fitted the black piano window stick-on things to my S/C and all went well, other than the fit for the driver's door one. I suppose it's the sheer number of cutouts but I needed to trim mine to get it to fit properly and it still doesn't look 'factory', so is coming off soon to be replaced with a genuine replacement. The other three are fine and an easy job.
cheers bellini.....
one thing i forgot to ask, was would i be right in thinking that i can fit the sticks ons around the door pulls, and it wont affect me taking the door cards off in the future? i think thats correct but can anyone tell me if i am right?
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 ![]() ![]() ![]() |
I've fitted the Powerful covers on the window switches and door pulls, IMO they look really good and fit well, the drivers window switch pack isn't perfect but as mentioned it's due to the sheer number of switches. I think fundamentally unless you knew the parts weren't genuine you'd be hard pushed to notice |
Looks nice I'm putting extra timber into mine too so I wondered how to remove trims from the window bins . Where did you get those trims from. I was considering having mine aqua printed in walnut depending on the match |
[Unnecessary quote removed]
Was referring to the strips on top of door pockets that's primarily what I'm after |
Googsy, i put the real parts on the door bins as i got some second hand..... its an easy job to do......here's a quick summary...
Cheers Andy |
