Home > Maintenance & Mods (L322) > door cappings
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
door cappings
hi everyone
does anyone know how to fit the take the cappings off of the storage bins on the doors, do you have to to take the door card off? i have looked on powerful uk and cant find anything....
andy
Post #201123 27th Jul 2013 1:36pm
Yes Andy you need to take the door panels off and there is a 10mm nut on each end inside the panel Thumbs Up
Post #201176 27th Jul 2013 8:54pm
andyleeds
cheers craig, am guessing its just clips to get he door cards off?
andy Very Happy
Post #201192 27th Jul 2013 10:14pm
plumajp
United Kingdom 2004 Range Rover Vogue Td6 Oslo Blue
Two torx screws along the door pocket and one in the door handle and a 10mm nut behind the Landrover badge and then it unclips.
5min job very easy
Post #201199 27th Jul 2013 11:14pm
andyleeds
ok so have done the door storage cappings which was straight foward and i have some door surrounds to put on (the powerfuluk sticky on ones) but i havent got any of the window switches yet, as am not sure whether to go stick on route or actual proper part...... so two q's
1) how easy are the proper parts to fit ie get the whole door card on and off? as i didnt have to actually take the door card off to get the other bits on, i just loosened it at the bottom not the top as the top bit looked a bit tricky
2) has anyone used the stick on ones for the window switches? craig says the door pull versions are good but i dont know about the window switches?
andy
Post #204898 20th Aug 2013 10:55am
I fitted the black piano window stick-on things to my S/C and all went well, other than the fit for the driver's door one. I suppose it's the sheer number of cutouts but I needed to trim mine to get it to fit properly and it still doesn't look 'factory', so is coming off soon to be replaced with a genuine replacement. The other three are fine and an easy job.
Personally, I'd fit the proper ones and avoid stick-on. I know others here who've had no problems.
I'd also be very interested in door card removal tips and techniques. Thumbs Up Si. <This is my name.
Post #204901 20th Aug 2013 11:10am
andyleeds
cheers bellini.....
i am not sure i fancy taking the whole door card off as they difficult bit would look to be the bit round the lock pop up.....
Post #204902 20th Aug 2013 11:12am
andyleeds
one thing i forgot to ask, was would i be right in thinking that i can fit the sticks ons around the door pulls, and it wont affect me taking the door cards off in the future? i think thats correct but can anyone tell me if i am right?
andy
Post #205054 21st Aug 2013 9:35am
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I've fitted the Powerful covers on the window switches and door pulls, IMO they look really good and fit well, the drivers window switch pack isn't perfect but as mentioned it's due to the sheer number of switches. I think fundamentally unless you knew the parts weren't genuine you'd be hard pushed to notice Smile
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #205154 21st Aug 2013 9:24pm
Googsy
Looks nice I'm putting extra timber into mine too so I wondered how to remove trims from the window bins . Where did you get those trims from. I was considering having mine aqua printed in walnut depending on the match Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #205162 21st Aug 2013 9:56pm
andy180
[Unnecessary quote removed]
Mine is the 9 piece facia kit from Powerful UK, it's a very good match colour wise and the finish is quite similar considering it's printed abs as opposed to proper timber veneers.
Here's the link Thumbs Up http://www.powerfuluk.com/products/range-r...ffect.html Now: BMW 640d M Sport, Alpine White
[URL=]
[/URL]
Post #205167 21st Aug 2013 10:15pm
Googsy
Was referring to the strips on top of door pockets that's primarily what I'm after Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #205171 21st Aug 2013 10:34pm
andyleeds
Googsy, i put the real parts on the door bins as i got some second hand..... its an easy job to do......here's a quick summary...
1. remove 3 torq screws from the door card, two by the side of the door bins and one in the handle pull, they are all different sizes so make sure you remember which one goes where.
2) ease the bottom of the door card away, they are on clips so just pull it, dont take all the way off as you dont need to, just half way up the door will do.
3) remove the 2x 10 mill nut at the back of the card, the one by the door edde is easy, the other one, just lie on your back and you can get your hand up the back to the other one.
4) push the bolt through of the existing strip, you need to muscle a little, also the strips are on clips at the front, but they essentially pull off.
5) put the new one on, reverse of the above 5 mins per door....
hope this is what you wanted?
andy
Post #205213 22nd Aug 2013 9:30am
Googsy
Cheers Andy Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #205222 22nd Aug 2013 11:02am
