Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 4 of 10 <12345678910>
pld118
Will the Sprinter jack leak?
Heard a comment off someone saying that when they drilled into the Merc Sprinter bottle jack to RR modify it, that oil or grease leaked out.
I've just put the very same jack in our spare wheel recess for storage. It's lying horizontally (in the bottom left recess space as you look down over the stored spare wheel). Does anyone please know if oil or grease is likely to leak out of this jack if left lying horizontal?
Thanks
Post #219652 30th Oct 2013 9:19am
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Mines horizontal in a small plastic tool box in the boot - not noticed any leakage from it. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #219653 30th Oct 2013 9:22am
i've also had mine horizontal for long periods, but i do rotate it 180 degrees every few months and no problems.. ... - .- -.
Post #219660 30th Oct 2013 9:45am
You don't drill into the jack at all to fit a RangeRover adapter. If you do it will leak. Laughing
You simply remove the fitted shaft head and fit the jack adapter in it's place by drilling a 16mm hole in the base of the adapter and preferably fitting it in place with a suitable pin.
What would leak oil is if you leave the jack adapter loose on the shaft and inadvertently push the shaft too far into the jack body.
The oil then has a good chance of leaking out round the top seal.
Post #219671 30th Oct 2013 10:07am
pld118
Thanks all... NDF Laughing perhaps my hasty wording. I didn't drill anything on mine but read about someone on the forum doing something that caused a spray or leak of oil Wink
Post #219830 30th Oct 2013 8:54pm
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
just done mine today ,ordered the ali block of ebay got my jack for 10 pounds of a friend ,drilled and fitted new roll pin ,great mod.
Post #220386 2nd Nov 2013 7:42pm
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
Did you trim alli block or use as it came just drilling it ?
Please could you post a couple of pics Thumbs Up
Post #220388 2nd Nov 2013 7:48pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Thanks
Thumbs Up Thank you to all contributors to this thread. I now have a jack fitted with the adaptor.
I hope I never need to use it, however feel much better knowing it's there. Very Happy
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #220394 2nd Nov 2013 8:36pm
pld118
@SparkyLee -
The images on page 1 of this post are helpful to answer your questions.
These blue Viking Horns are how the top of the jack shaft looks when you buy it. The horn is removed by tapping out the metal pin from the horn (I lined up a thin Allen key and tapped the Allen key until the pin came out):
[/quote]
This next image is like the BMW adaptor that is added to the original jack shaft that is exposed after removal of the blue horns:
This linked post should clarify but in short after tapping out the metal pin you are then left with a 16mm diameter top section of jack shaft. The BMW adapter needs a hole 16mm dia drilled centrally in the bottom of the circular base and should be drilled 16mm deep. It then fits on the top of the jack shaft. Fuller information is on this linked post but the jack is quality and the excellent advice on how to convert it is spot on and clear:
http://www.fullfatrr.com/forum/topic20599....p;start=30
Post #220400 2nd Nov 2013 9:18pm
Sparkylee
Hi yes I'd read that bit and understood the context but the link to the adaptor shows a block with a lot larger base !
Do people trim this or drill right through the 63mm base to fit the locking pin after 16mm hole for the shaft
It was a picture of this block fitted I was after cheers
Sorry to be a pain :oops:
Post #220408 2nd Nov 2013 10:24pm
pld118
Picture of my jack after removing the blue horns and with the underside of the BMW adaptor on show to the right of the jack. The shaft hole should be drilled into the centre of the BMW adaptor base face that is on view in my image.
The BMW adaptor doesn't actually then need a hole drilled into the side wall to accommodate a new fixing pin because in fact the BMW adaptor will sit nicely onto the shaft after the 16mm centre hole is drilled into the adaptor, although mine has had the pin hole drilled in:
Post #220419 2nd Nov 2013 11:12pm
Sparkylee
Cheers Thumbs Up
Post #220428 2nd Nov 2013 11:29pm
wealy
Interesting thread. What is the reason for this? Is the existing jack that comes with the car useless / dangerous / flimsy ??
Post #220445 3rd Nov 2013 10:04am
existing scissor jack does work and many have used it but it is very flimsy and really not up to lifting the heavy range..using both of these jacks you should be able to safely replace a wheel on the side of the road for instance.. ... - .- -.
Post #220451 3rd Nov 2013 10:36am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I've just had to use the Land Rover supplied scissor jack as I had a puncture, it collapsed!! Luckily the wheel was still on the car when it happened.
I'd best invest in something more substantial.
Post #232040 30th Dec 2013 7:46pm
