![]() | Home > Maintenance & Mods (L322) > 2006–2009 Headlights & External LED/'Xenon' bulb upgrade |
@Prop - noted thanks. Whilst saying not too sure, nor am I discounting these bulbs. I suppose trialling a pair of £20 bulbs, if they achieve what you are after with no obvious negatives, then that is a significantly cheaper solution than changing both rear light units, particularly if you like the existing unit anyway. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35710 ![]() ![]() |
what my learned friend Prop says Ryan...
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Stan, maybe Craig would know the answer, I am pretty certain he will have had these lights apart at some point. |
i suppose i can wait till i fit my cheapo's and see what's actually there..
Going to order a pair of Cree LED indicator bulbs today, so from this thread, which of the 4 types would you be inclined to go for please:
The one I would have gone for is showing as not available any longer.
I actually emailed online4bulbs about the 30W/£30 pair of UK supplied indicators this morning. Response pending and the ebay supplied mobile number 'is not recognised'... |
when you do get your bulbs Ryan ,can you only fit one side and do a video so we can see the comparison of OE and LED.. |
Or a comparison of an OE one flashing versus the upgrade one smouldering |
The 2 main indicator bulbs of interest from this thread were these:
pld118, I am confused, the £20 a pair lights from China show up as 7watt bulbs not 30watt. These bulbs are approx half the lumen output of the 30watt £30 a pair bulbs which are no longer available. |
So it looks like you will be getting the single CREE led with 12SMD leds giving an output of 400 lumens which is still much higher than a standard 21watt incandescent bulb.
