![]() | Home > Maintenance & Mods (L322) > 2006–2009 Headlights & External LED/'Xenon' bulb upgrade |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
if not Ryan's lights it will be glasgow burning... |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
Had a spare hour this afternoon and have changed the driver's sidelight bulb and the driver's side full beam bulb as follows:
@Prop, I thought £10 for the pair of sidelight bulbs was cheap and the difference in the performance of the lights and the look they give as well is surely worth £10 and 10 minutes 'work'. Maybe they are slightly erring towards a bluer tinge than the OEM dipped beam xenon bulb, however the match is excellent and side by side it all looks right.
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
The cornering lights you mention are rated as 6000k so will be very slightly blue in hue. The will most likely be a very similar colour to the new side light bulbs you fitted and will certainly be a much closer match in terms of colour compared to the existing halogen cornering bulbs.
Do you think I did something wrong?
It,s a parody reference to how bright we hope the indicator bulbs will be compared to the current candles fitted in the rear range rover indicator lights. |
Prop,
Morning Stan,
thumbsup is for the supply of the diagram Ryan..
Thanks Stan |
As Stan states the rear tail/fog lights are different from the front side light bulbs. Not sure what benefit there would be in replacing these, but nothing to stop you from doing it I guess.
Which LED side repeaters to order (they must compliment and perform/ look right with “amber” 30W equivelant [6 x 5W Cree], 500 Lumen, all round LED indicator bulbs that are now fitted to the car and which although described as amber, are very much of the right up to date and modern LED yellow look)?
i think they must be amber on the sides Ryan.. ... - .- -.
| All times are GMT |
