Home > Technical (L322) > 4600 MILES BONG !!!! SUSPENSION FAULT
Martin
Site Admin
That foam filter referred to is the air dust filter, not the drier unit.
Post #225761 28th Nov 2013 7:41pm
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
so in a range rover the compressor has a drier unit ................
sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #225762 28th Nov 2013 7:42pm
Martin
Site Admin
That's what I just said Wink
Post #225764 28th Nov 2013 7:43pm
salb
thanks, more work to do, more stress
now just find where its located
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #225767 28th Nov 2013 7:48pm
Martin
Site Admin
OK well you did ask for help Confused
It's on the compressor unit, black "pot" with two pipes going into a red marked socket and blue marked socket.
Post #225768 28th Nov 2013 7:49pm
salb
thanking you again, Thumbs Up Thumbs Up
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #225770 28th Nov 2013 7:54pm
salb
Hi Everyone,
T24 RES has got me started on this project, finally took the compressor out,
and took the drier unit to bits and took the silica beads out and as we speak are drying out
in the oven, not that i could tell that they were damp.
New brass silencer will be ordered from dan tomorrow, fingers crossed it will it all back together again,
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #283612 29th Sep 2014 6:34pm
Sandyt
Hi Sal the p38 air suspension was the same albeit a bit simpler and suffered all sorts of problems if the drier wasn't drained and looked after so they can and do throw up lots of faults sure the air suspension on ours will be the same sort of system just more complicated good luck
Post #283627 29th Sep 2014 7:08pm
miggit
Hi, just to make you aware, you can buy new silica beads and felts on fleabay for around a score, then all will be new! I got a kit to do mine after the hole lot went Pete Tong in Birmingham, I made it as far as Northampton before the front hit the stops and a very slow drive home. So far I've replaced the front struts and rebuilt the compressor, as it was slow to start with I then got the air dryer kit, thinking that it must be blocked with powdered compressor ring. When the kit arrived, the car started to go up and down a lot quicker, so I haven't done it yet!! Think mine was just bedding the ring in! Yesterday I couldn't spell Engineer... Today I are one!
Post #283699 29th Sep 2014 9:59pm
salb
Hi and thanks,
Yes I'm going to order the filter pads I already have
The silica balls as the originals I just threw out after
Weighing how many I need.
Thanks for the advice RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #283711 29th Sep 2014 11:43pm
salb
Update
Good evening ,
Well approx one year later and a kick up the backside from T24 RES,
The compressor has been stripped and repaired and put back and basically it there was a double issue.
1. Drier unit, the silicon beads and filters needed replacing.
2. Conical brass muffler was blocked so needed replacing.
Thank you all for your input, now onto the next project, Sat Nav Antenna.
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #284411 4th Oct 2014 7:24pm
T24RES
Excellent Thumbs Up Ian
Post #285447 10th Oct 2014 9:38am
