Home > Technical (L322) > 4600 MILES BONG !!!! SUSPENSION FAULT |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
That foam filter referred to is the air dust filter, not the drier unit. |
28th Nov 2013 7:41pm |
That's what I just said |
28th Nov 2013 7:43pm |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
thanks, more work to do, more stress
28th Nov 2013 7:48pm |
OK well you did ask for help
28th Nov 2013 7:49pm |
thanking you again,
28th Nov 2013 7:54pm |
Hi Everyone,
29th Sep 2014 6:34pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2217 |
Hi Sal the p38 air suspension was the same albeit a bit simpler and suffered all sorts of problems if the drier wasn't drained and looked after so they can and do throw up lots of faults sure the air suspension on ours will be the same sort of system just more complicated good luck |
29th Sep 2014 7:08pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi, just to make you aware, you can buy new silica beads and felts on fleabay for around a score, then all will be new! I got a kit to do mine after the hole lot went Pete Tong in Birmingham, I made it as far as Northampton before the front hit the stops and a very slow drive home. So far I've replaced the front struts and rebuilt the compressor, as it was slow to start with I then got the air dryer kit, thinking that it must be blocked with powdered compressor ring. When the kit arrived, the car started to go up and down a lot quicker, so I haven't done it yet!! Think mine was just bedding the ring in! Yesterday I couldn't spell Engineer... Today I are one!
29th Sep 2014 9:59pm |
Hi and thanks,
29th Sep 2014 11:43pm |
Good evening ,
4th Oct 2014 7:24pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Excellent Ian |
10th Oct 2014 9:38am |
