![]() | Home > Maintenance & Mods (L322) > Melting cornering (headlight) or design flaw? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
its a design flaw then Craig? ... - .- -.
Thanks Craig,
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
It's a design flaw and the only remedy to correct the melted lens is to replace the entire headlight unit, which is what my S/C had done by the dealer when noticed. Si. <This is my name.
Very common. And LR would have been in trouble if more people had noticed. But you do have to look closely - and most people don't.
Thanks Steve |
Remove the OE halogen cornering bulbs and replace them with LED seems to be the remedy to prevent this melting of the unit. |
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
So will this just be a matter of swapping bulbs or any changes to the wiring required??
just swop the bulbs Mike... |
Thanks Stan... Will start looking where to find them over here... |
Mike, it really is simple. Remove the 3 grille screws, lift off the front grille, remove the 3 headlight screws, towel under headlight to stop bumper getting scratched, partially slide headlight out over towel, unplug headlight cable, fully slide headlight unit out, take off round cornering housing cover, anticlockwise turn of cornering bulb holder, unclip halogen bulb and replace with plug and okay 'off the shelf' LED bulb. Each headlight can be done in under 10 minutes. These are the bulbs I have used. Been using for a week now and very pleased with them. I got them for £25/pair delivered to mainland UK.
Awesome... Sounds really easy and since I'm about to enjoy vacation should have time get this sorted...
Only comment I will make is that LED's are great as DRL's and marker lights, but don't cast light like the OE halogens. If you don't need your cornering lights to actually fulfill their original function (i.e. light the road as you turn into a side road) - then all is good. If you do then you need to shell out for really really good lamps!!! Land Rover Addict
Hmmm, living in the country side, the extra lights when cornering is always handy at night... |
