![]() | Home > Maintenance & Mods (L322) > 2006–2009 Headlights & External LED/'Xenon' bulb upgrade |
The seller has since said that for this car they recc this bulb?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
first of all its white not red, secondly i cant figure how it can be dual wattage [21w and 5w].. ... - .- -.
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Stan, just getting back to the 50watt Cree bulbs.
ahh man, i thought i won that fight.... |
Stan, just wanted to keep you informed so you know the correct specs and can better calculate your risks, I am confident using just 2 of these bulbs at the rear should be ok. But running front and rear 50watt would be much more risky. And with all the conflicting info supplied its better to know for sure, I learn't a long time ago to take any specs given with eBay stuff with a pinch of salt.
i only suggested the rear brake lights as a comparison because of their brightness but how do you know they are 5050's?
The eBay link that PLD118 gave to the bulbs in question states:
a mis-constrution here Prop, i was referring the the OE led brake light on the FF... ... - .- -.
Ordered 4 of these for £27.50 delivered.
i dont think anyone has replaced the OE bulbs with leds so this will be interesting ..dont forget the pics and your opinion on these Ryan. |
I experienced initial minor problems fitting and/or removing aftermarket LED cornering bulbs and rear tail/ fog bulbs which caused some bulbs to break. This was in part due to the dry joints that can prevail when inserting aftermarket LED bulbs, partly it was due to bayonet pin position (on the rear tail/fog bulbs) and in part it was due to my fitting technique... gently does it... and I'm satisfied that these bulbs are of good quality and fit for purpose. Fortunately, the supplier of both bulbs is reputable and very customer focused, promptly supplying replacement bulbs FOC and without quibble.
