Home > Maintenance & Mods (L322) > supercharger oil change
Page 2 of 3 <123>
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
Smile Smile Smile thanks guys
I updated the write up with some more specific informations. Thumbs Up
If you have more questions. Do not hesitate to ask me.
Post #249998 23rd Mar 2014 11:33am
thank you for that Hugi, put into the wiki.. Thumbs Up ... - .- -.
Post #250009 23rd Mar 2014 1:54pm
Excellent write-up. Thumbs Up Si. <This is my name.
Post #250064 23rd Mar 2014 6:51pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I got mine done by the guy who sells the kits on eBay. He was a very nice guy and happy to talk anything through, so if you're stuck I'm sure a phonecall to him will get you sorted. However HUGIs guide looks great. One thing I would be careful of though is if you take of the aluminium intake plenum you put it back with a torque wrench. If you do it by guessing it doesn't always fit correctly and can leak air.
Also I had a custom intake pipe done instead of that stupid black plastic thing. Added minimal (but nice) supercharger noise and there was a nice increase in throttle response.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #250131 23rd Mar 2014 9:39pm
HUGI
@TheAllSeeingPie do you have pictures of your custom intake pipe? Thumbs Up
I dont like the black plastic thing.
Great point with the torque for the intake plenum. However I did mark the position of the buckle so I knew how tight it was before.
Post #250135 23rd Mar 2014 9:59pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Excellent write up, this is on my 'to do' list.
Also really interested in ditching the silly ported tube. Do you have some more details?
also; @Hugi much to the embarrassment of many a native English speaker, your English is great!
Thanks.
Steve
Post #250182 24th Mar 2014 10:14am
TheAllSeeingPie
Post #250192 24th Mar 2014 11:45am
pld118
If the garage recently had the engine out on ours, would anyone know if the supercharger oil would have had to be changed at that time anyway?
Thanks.
Post #308039 26th Jan 2015 7:59am
Ryan, I doubt the oil would have been changed during that process, although I'm happy to be proved wrong.
I'd assume not.
Interestingly, the recent health check my SC had done by Conrico in Chertsey, the garage refused to change the SC oil as their computer information suggested there was a metal bar directly inside the SC casing once the allen nut was removed, thereby preventing syringe oil removal. I asked them to actually check, but they declined on the basis they 'may' cause damage by doing an operation they clearly weren't familiar with.
My SC's due a service any time now, so I'll be booking her in somewhere that is amenable to doing the oil change. I tried doing it myself but chickened out taking the SC snout off. Si. <This is my name.
Post #308069 26th Jan 2015 10:39am
pld118
Cheers Si. Huigi's write up does suggest this oil change might not be for the feint of heart novice and I note he did the job with a mechanic friend.
Post #308121 26th Jan 2015 12:49pm
crispy2
Australia 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
My 2007 S/C has done 65,000 kms and I've had a read of this and the process seems pretty straight forward though undoubtedly more awkward than it seems. In any case, is it too soon to do yet at 65k? It is also a very easy 65k too.
What do you reckon?
Pete. '07 4.2 S/C
'13 X3M
Post #322290 12th Apr 2015 1:26pm
DanRRL322sc
HUGI wrote:
so lets start with the job:
First imagine a SC without this silly plastic cover. If you like I can take pics how to remove the cover too.
here it is:
now you see a black plastic part with the weird shape connected to the Airfilter: Air Intake Duct Boot (PHD500075)
this you can remove very easily.
It will look like that:
This screw you need to remove to suck out the oil.
and on the technical diagram:
It needs a specific allen key. (We didnt have so we had to make one to fit) Size: (3/16)
Removing the nut there seems complicated with the throttle body intake in place.
So we decided to remove the throttle body intake (part no: LR005192)
Here you can see which Parts you need to remove. It is Part 1 and 4.
First you have to undo in the back and lift the throttle body intake and pull it towards you.
Then it is pretty easy to undo the nut and take out the old oil and refill with new one. Probably the nut is stuck and you need to spray it with some WD40. I would advise you to put a rag down there so if the nut or the allen key falls you can grab it easily.
I used the syringe which was included in the Kit I bought from EBAY. I got 170ml out of the Supercharger. The Oil capacity is 215ml. To get out as much as possible lift the car in the back a bit so the oil is flowing to the front of the Supercharger.
Then refill the Supercharger with the same quantitiy of oil until it overflows (second reason to put a rug or a piece of cotton there) Just tight the nut again and you are done.
Please be aware! You need special Oil. I read some topics somewhere else about people using normal engine oil?!! Censored
Hope you understand my approach even if English is not my first language and I am not very familiar with technical terms.
Gutted!!....the pictures have gone Sad 1988 Classic 3.5 EFI in Green - GONE.
1993 Classic 3.9 Vogue SE in Green - GONE.
1997 P38 4.6 HSE in Blue - GONE.
2002 P38 4.6 Vogue in Black - GONE.
2007 L322 4.2 SC in Java Black.
2007 Audi TT 3.2 V6.
1988 Porsche 930 turbo.
Post #685102 8th Feb 2024 5:08pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I know! They would have been very helpful!
Post #685107 8th Feb 2024 6:00pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I changed the oil a while back and posted some pictures here
https://www.fullfatrr.com/forum/topic55392-45.html
Just scroll down a bit. It is much easier to do than you might think, just a little fiddly if you have large hands, also don't forget the rag you don't want to lose the drain plug
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #685143 9th Feb 2024 12:34am
DanRRL322sc
That is perfect and a massive help! Thank you David Thumbs Up 1988 Classic 3.5 EFI in Green - GONE.
Post #685153 9th Feb 2024 8:36am
Page 2 of 3 <123>
