![]() | Home > Technical (L322) > Yet another efing problem vibration through car :update |
trainmanone Member Since: 26 Jul 2012 Location: stockport Posts: 201 ![]() ![]() ![]() |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Does it feel like your travelling over a cattle grid? |
yes in a way I think it dose ,don't say gear box |
I had the engine mounts replaced, then all injectors, finally the TC.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
What about swapping front wheels with rears and seeing if that makes a difference? Previously..
If I'm not mistaken you can test for torque convertor lock-up clutch failure by simply pressing the brake pedal when the vibration is present.
It only vibrates at 55-60 mph used to do it on left hand bends on motorway but now only in straight ahead with power on take foot off gas no vibration. All in all the vibration has been there sience before march |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
when you have some time, replace each wheel in turn, with the spare wheel, and test drive, my money is on a damaged wheel. ie out of roundness. ive had experience of this, especially when braking from speed. and 'attacking' roundabouts, (ie fastish.) start with the left front wheel. and do a few miles on a carraigeway etc, through your proven route...then, move it to another corner. you might be better off borrowing someone's trolley jack, to save yourself some extra hassle. this is a cheap and proven way to find/prove a 'wrong' wheel. its what the garage will probably do anyway....
Thanks for the advice guys,going to leave it now till have time off work might burn the ting if it is box and tc unles someone wants to give me £4000 for it have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis. |
ok guys, had a look today a quick one any way here's the findings , n/s front car on ground push top of wheel slight thumping can be felt and heard !! do same to o/s front nothing felt or heard.
hi gang, had a good look today jacked front end up n/s pass side there it slight play when you grip wheel at top and push it inwards cant see where movement is doesn't seem to be there when pushing side to side .,o/s drivers side all ok
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Check out the ball joint connected to the Upper Suspension Arm and also the Ball Joint on the Control Arm, they could be worn and causing a rattle / vibration.
It's nearly always part no.9 .... The lower control arms/transverse link... Tons of posts about them and loads of photos.
well gang had a good look with a pry bar nothing has play in it.........
