Home > Technical (L322) > Yet another efing problem vibration through car :update
Page 1 of 4 1234>
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
Censored Yes me again just put new control arms track rod ends ball joints on front ,new tyres all round balanced as well. Full geo setup and getting vibrations at 30 mph more noticeable at between 55-70 mph when under load i.e. power on.
took it back to garage who did geo setup (on a hunter system)he says every thing ok with set up .
was getting vibration on long left hand bends at 55 mph with power on before work was done ,any help would be great.
don't want to start throwing money at it any more ,haven't got any anyway lol
thinking along drive shafts prop shafts have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #274282 4th Aug 2014 6:09pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Does it feel like your travelling over a cattle grid?
Post #274290 4th Aug 2014 7:12pm
trainmanone
yes in a way I think it dose ,don't say gear box Big Cry Big Cry Big Cry have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #274292 4th Aug 2014 7:17pm
Discotigger
It could be any one of several things...
Get all the bushes checked, and check the tightness of all the bolts for the front and rear linkages.
Next, get the hydraulic engine mounts checked, vacuum test the mounts and check the pipes and solenoid for vacuum.
Check the servotronic valve, this can cause vibration if it's on its way out.
Check the diesel injectors.
Finally, it could be the TQ is on its last legs. Big Cry
Hope it's not that though and it's one of the others! Thumbs Up
Post #274315 4th Aug 2014 8:34pm
PaulB
I had the engine mounts replaced, then all injectors, finally the TC.
Big Cry
Post #274317 4th Aug 2014 8:53pm
What about swapping front wheels with rears and seeing if that makes a difference? Previously..
Post #274319 4th Aug 2014 9:12pm
If I'm not mistaken you can test for torque convertor lock-up clutch failure by simply pressing the brake pedal when the vibration is present.
Pressing the brake pedal releases the lock-up clutch solenoid and disengages the lock-up clutch.
If the vibration disappears when you press the brake pedal it's a good indication your torque convertor lock-up clutch is failing. New torque convertor I'm afraid.
If you leave it, the failing lock-up clutch will take the gearbox with it. Big Cry
Post #274331 4th Aug 2014 10:08pm
trainmanone
It only vibrates at 55-60 mph used to do it on left hand bends on motorway but now only in straight ahead with power on take foot off gas no vibration. All in all the vibration has been there sience before march Rolling Eyes have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #274348 5th Aug 2014 7:03am
johnboyairey
try this..
when you have some time, replace each wheel in turn, with the spare wheel, and test drive, my money is on a damaged wheel. ie out of roundness. ive had experience of this, especially when braking from speed. and 'attacking' roundabouts, (ie fastish.) start with the left front wheel. and do a few miles on a carraigeway etc, through your proven route...then, move it to another corner. you might be better off borrowing someone's trolley jack, to save yourself some extra hassle. this is a cheap and proven way to find/prove a 'wrong' wheel. its what the garage will probably do anyway....
note, wheels are balanced at relatively slow spin speeds, as the system is very sensitive, but with the suspect wheel under suspition, another faster spin up, might show the slight buckle.
then, its just a visit to ebay, or a dismantler, for another single alloy wheel, to prove indefinitely.
if you are on non genuine LR alloys, i will put good money on this theory.
Post #274358 5th Aug 2014 8:24am
trainmanone
Thanks for the advice guys,going to leave it now till have time off work might burn the ting if it is box and tc unles someone wants to give me £4000 for it have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #274421 5th Aug 2014 3:14pm
trainmanone
ok guys, had a look today a quick one any way here's the findings , n/s front car on ground push top of wheel slight thumping can be felt and heard !! do same to o/s front nothing felt or heard.
haven't got time till Monday
to get a jack under and have a poke around ,think this could be problem .
ideas please on a post card or back of envelope lol
thinking wheel bearing = no grumbling
drive shaft /cv joint =no clicking
its had new ball joint but not done lower arm but no play in it as far as I can tell. have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #274843 7th Aug 2014 6:17pm
trainmanone
update
hi gang, had a good look today jacked front end up n/s pass side there it slight play when you grip wheel at top and push it inwards cant see where movement is doesn't seem to be there when pushing side to side .,o/s drivers side all ok
I'm now thinking this is source of vibration like I said its as though the wheels need balancing but have been done
any ideas
best regards pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #275808 14th Aug 2014 4:11pm
Discotigger
Check out the ball joint connected to the Upper Suspension Arm and also the Ball Joint on the Control Arm, they could be worn and causing a rattle / vibration.
Also check the bushes on the Suspension and control arms for play or excessive wear.
Post #275824 14th Aug 2014 6:37pm
It's nearly always part no.9 .... The lower control arms/transverse link... Tons of posts about them and loads of photos.
Post #275833 14th Aug 2014 7:29pm
trainmanone
well gang had a good look with a pry bar nothing has play in it.........
but did find a chunk missing out of brake disc on the edge where it fastens to the hub
could this be the cause ??????
Post #277138 22nd Aug 2014 5:00pm
Page 1 of 4 1234>
