![]() | Home > In Car Electronics (L322) > 2002-2006 Replacement head unit running Android |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8782 ![]() ![]() ![]() |
Fitting thread here....
Looks fantastic and great value.
Joe
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Looks good Haylands
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 476 ![]() ![]() ![]() |
This is very tempting; as already said, if mine goes TU I shall be looking at doing the same. And as I'm just over the bridge I shall be likely to take advantage of your advice regarding fitting |
87RJD Member Since: 01 Dec 2013 Location: Wokingham Posts: 103 ![]() ![]() ![]() |
I agree, looks brilliant, If I still had my TD6 it would be on the list. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Very impressive. |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Does it have DAB radio or normal FM etc ? I am really missing DAB in the car....... "On first name terms with my local Dealer......now."
Yep mine had DSP, wired it directly into the speakers as they came out of the Amp, it would handle 8 speakers in total but it does have an additional sub woofer out with the RCA lead so I dare say you could wire that in, personally I'm not into music in cars much so I've just done the basics and it sounds OK to my non Dolby ears!!! It's too loud at 3/4 volume so it has a decent output.... It is plug and play if you have the original Amp and can use that in which case it should be as original... I took a permanent 12v feed from the Amp, a switched from the radio plug and the aerial amp from there as well, and that was it.... The original Head unit will fit in the place of the CD Changer in the glove box and the wires will reach so you could run both setups and just use the old head unit for settings, mines a petrol so doesn't have a FBH so the only thing I've lost is the clock setting and I've taken that out so no probs.... I know these units take a time to come on, after all they're mini computers, or big smart phones, so have to boot....Just timed it and it takes 20 seconds to come on, radio playing after another 4 seconds and sat nav starting about 4 secs after that so not a great deal of time, this one also remembers what you were listing to and looking at the last time you used it so that's an improvement.... Main sat nav is IGO primo, see here for details of it, it is a good system and does all you need and more http://files.car-vision.co.uk/files/primo/primo-user-manual.pdf Should be enough pics there but if you want to see it on my screen let me know.... It came with full Europe maps even Iceland on it so should be all you need... there from 2012 but as far as I can make out that was the last update. It will run TomTom software as well, and off course things like Google maps or any other Android App
I'm Hull side of the bridge, pop round anytime you like for a look/chat... and I'll certainly help you fit one if you like, to route the cable nicely you have to remove a fare bit of interior including the passenger seat so it's not a 10min job....
Well.... alright then if you ask nicely I'll swap my FF for yours, then you can have one........
It was this one, cost a staggering £3.73 !!!! They do a range of colours as well.... http://www.ebay.co.uk/itm/281102715008?_tr...EBIDX%3AIT Was easy enough, panel off, take the clock out, remove the front and the lens, mask up and spray the inside of the lens black then take the front off the voltmeter and hot glue the voltmeter and smoked cover in place, there is a switched live in the loom running down the outside of the console on that side
The radio is just an App and there are DAB radio Apps so I suppose you could run one of them....
Sat nav is fine, see the link above, as I've said the original unit will fit where the CD Changer is so you don't even lose any glovebox space.... Don't forget you will need the longer lead which isn't included. Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
ahh a quick revisit to my watched items on ebay and I realise that I am looking at a completely differemt unit. Although the one I am watching (and have submitted an offer on) has a longer loom specially for RR, it looks as though your head unit is much better?
Steve,
Thanks for that |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Very interesting. It's nice to know there's an alternative. Is there one for the 2007+ cars with Terrain Response, etc.? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
the only thing i have found is this,
