![]() | Home > Technical (L322) > pressure static when filling |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
@ nicedayforit
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Nicedayforit, my pressure switch was clean on the thread as well, as the switch has a rubber O ring and the switch fits in the tank recess, when tighten up is wont leak air. If it dont work.......burn it!
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Thought it must be sealed somehow. |
Sadly, not fixed for me. Made it @ 6 miles from home this morning before faulting. Same fault, so haven't moved the problem |
Yes |
Not wanting to count chickens but have now been 2 + 1/2 days fault free (6 journeys @ 100 miles in total) since I reset (all ecus) Monday morning. Pretty certain I did the same after fitting the new sensor but at my age.....
Fingers crossed for ya mate |
B |
oh |
Compressor coming out on the bench tomorrow, see if I can find the reed valve Haylands mentioned. Will also pull it apart a bit to see what else I can find. Having done bagpipe andy's repair only recently am guessing my piston broke (gag) |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8745 ![]() ![]() ![]() |
Hopefully be the read valve Joe, can't see it would be much else, unless the piston ring has broken....
Should have done all this when I had it out last time |
