Home > Technical (L322) > pressure static when filling
Page 2 of 4 <1234>
@ nicedayforit
Yes, that's what I was expecting, but old one clean as a whistle on the thread. Must on the mating face at the end of the thread? No leak or hissing here Wink .
Post #279460 6th Sep 2014 6:00pm
I think when my pressure switch requires replacing, as I'm sure it will, Whistle I'll use a bit of ptfe just to be sure.
Post #279474 6th Sep 2014 6:59pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Nicedayforit, my pressure switch was clean on the thread as well, as the switch has a rubber O ring and the switch fits in the tank recess, when tighten up is wont leak air. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #279496 6th Sep 2014 9:02pm
Thought it must be sealed somehow. Thumbs Up
Post #279512 6th Sep 2014 10:12pm
Sadly, not fixed for me. Made it @ 6 miles from home this morning before faulting. Same fault, so haven't moved the problem Sad
Think it will have to be a new compressor next! Big Cry .
Post #279680 8th Sep 2014 8:22am
Welshdragon
Big Cry Big Cry
Tim did you clear all faults stored, not just the eas ones in the eas and lcm? If it dont work.......burn it!
Post #279684 8th Sep 2014 8:36am
Yes Crying or Very sad .
Post #279719 8th Sep 2014 11:44am
Welshdragon
Big Cry Big Cry
Censored , that's a pita.
How long does it take from access height to off road height, to re cap mine on my thread it was between 1min 20 sec to 1 min 26 sec, reservoir full to start with.
If yours is the same ish or under sure it couldn't be the compressor as mine still takes this long to raise. If it dont work.......burn it!
Post #279732 8th Sep 2014 1:01pm
Not wanting to count chickens but have now been 2 + 1/2 days fault free (6 journeys @ 100 miles in total) since I reset (all ecus) Monday morning. Pretty certain I did the same after fitting the new sensor but at my age.....
Will report back again Friday pm unless this hopeful post generates a fault in the morning Evil or Very Mad .
Post #280220 10th Sep 2014 6:39pm
Welshdragon
Fingers crossed for ya mate Thumbs Up If it dont work.......burn it!
Post #280232 10th Sep 2014 7:26pm
B Censored ks Evil or Very Mad
5 miles into journey into work and up it popped.
Cleared fault once I got to work, then did the access to off road test. Gave up after 3 minutes of waiting for it to get there. So off to find a new compressor, methinks Embarassed .
Post #280322 11th Sep 2014 8:19am
Welshdragon
oh Censored
At least you now know which way to go....compressor Big Cry If it dont work.......burn it!
Post #280380 11th Sep 2014 12:42pm
Compressor coming out on the bench tomorrow, see if I can find the reed valve Haylands mentioned. Will also pull it apart a bit to see what else I can find. Having done bagpipe andy's repair only recently am guessing my piston broke (gag) Laughing .
Post #280583 12th Sep 2014 5:45pm
Hopefully be the read valve Joe, can't see it would be much else, unless the piston ring has broken....
Could try cleaning out or drilling the brass air filter inlet, and checking the other filters.... also have a look at the dryer, comes apart easy, stuck my granules in the oven at 120deg for 30 mins to dry them after my swimming lesson!!!
Good luck.. Pete
-Click here for Thread-
Post #280604 12th Sep 2014 7:13pm
Should have done all this when I had it out last time Evil or Very Mad
http://www.fullfatrr.com/forum/topic14320.html .
Post #280659 12th Sep 2014 11:32pm
Page 2 of 4 <1234>
