Home > Maintenance & Mods (L322) > Engine blower running all the time? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
handy to know that those symptoms relate to a faulty fsr, glad its sorted alan.. ... - .- -.
15th Oct 2014 8:26am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
'tis possible the fsr has gone again. One of my replacements "went" quite quickly. I noticed some shorting had been taking place around the connector, so it was possible I hadn't quite got it back together properly (had the same problem when i fitted new radiator and a hose blew off!)
22nd Oct 2014 5:44pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6669 |
its genuine LR.
22nd Oct 2014 5:47pm |
Yes rear is seperate (fuse in rear ndfi will confirm) and has its own FSR too. .
22nd Oct 2014 10:38pm |
So what's the common denominator then? Got - 2017 SDV8 Autobiography in Loire Blue
23rd Oct 2014 9:21am |
Seems the problem is solved. Removed the FSR, checked the blower by bridging across the connector.
23rd Oct 2014 5:33pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7931 |
Glad that's sorted, wonder why it took the rear out as well, maybe the rear runs through the front as well..... Pete
23rd Oct 2014 6:12pm |
^ it seems that way. The rear fan speed switch doesn't seem to do anything but is controlled by the front fan control.
23rd Oct 2014 6:31pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
If you press the rear fan switch on the front central console, doesn't that allow fan speed adjustment (ie you can inhibit the rear control to stop the kiddies playing?) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
23rd Oct 2014 6:37pm |
Is that the button on the bottom right hand side? Got - 2017 SDV8 Autobiography in Loire Blue
24th Oct 2014 9:15am |
That's the one..icon looks like air-flow lines GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
24th Oct 2014 10:21am |
Ah, I though that was for additional demisting for the rear side windows!
24th Oct 2014 10:43am |
TBH Alan..i only found out by accident GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
24th Oct 2014 10:45am |
