Home > Maintenance & Mods (L322) > Engine blower running all the time?
handy to know that those symptoms relate to a faulty fsr, glad its sorted alan.. Thumbs Up ... - .- -.
Post #286517 15th Oct 2014 8:26am
I went out in car for the first time since replacing the FSR last week and thought it was rather chilly so decided to turn up the temperature. Still felt that the car wasn't warming up, so i thought I'd turn up the fan, only to discover that the fan wasn't running at all!
No amount of coaxing would bring it on, even hitting the "max" button had no effect.
With the engine off but the ignition on, I can hear a whirring kind of noise from behind the dash area when the heater is on, and this stops when the heater controls are turned off.
I've checked all the relevant fuses, so I'm starting to wonder if the FSR I fitted last week could be faulty?
edited to add that the rear blower isn't running either!
anyone got any other thoughts? Got - 2017 SDV8 Autobiography in Loire Blue
Post #288114 22nd Oct 2014 3:38pm
'tis possible the fsr has gone again. One of my replacements "went" quite quickly. I noticed some shorting had been taking place around the connector, so it was possible I hadn't quite got it back together properly (had the same problem when i fitted new radiator and a hose blew off!)
Was it genuine or third party? I have been running happily for the last couple of years on a £16 jobby of eBay (I bought three so two spares waiting to happen now I have mentioned it).
Was going to say the whirring is the temperature monitoring fan but thought that ran all the time regardless of heater settings?
Check connections and then check again. Difficult spot to do it I know Smile .
Post #288127 22nd Oct 2014 5:44pm
its genuine LR.
the whirring only comes when i turn the heating on.
I'm a bit confused why the rear isn't working, i thought both were totally separate? Got - 2017 SDV8 Autobiography in Loire Blue
Post #288129 22nd Oct 2014 5:47pm
Yes rear is seperate (fuse in rear ndfi will confirm) and has its own FSR too. .
Post #288198 22nd Oct 2014 10:38pm
So what's the common denominator then? Question Got - 2017 SDV8 Autobiography in Loire Blue
Post #288230 23rd Oct 2014 9:21am
Seems the problem is solved. Removed the FSR, checked the blower by bridging across the connector.
Put it all back together and all is well! So perhaps a bad connection at the FSR methinks. Thumbs Up
I was dreading having to replace the blower Shocked Got - 2017 SDV8 Autobiography in Loire Blue
Post #288358 23rd Oct 2014 5:33pm
Glad that's sorted, wonder why it took the rear out as well, maybe the rear runs through the front as well..... Pete
-Click here for Thread-
Post #288365 23rd Oct 2014 6:12pm
^ it seems that way. The rear fan speed switch doesn't seem to do anything but is controlled by the front fan control.
I was sure I read they were totally separate. Got - 2017 SDV8 Autobiography in Loire Blue
Post #288369 23rd Oct 2014 6:31pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
If you press the rear fan switch on the front central console, doesn't that allow fan speed adjustment (ie you can inhibit the rear control to stop the kiddies playing?) GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #288370 23rd Oct 2014 6:37pm
Is that the button on the bottom right hand side? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #288526 24th Oct 2014 9:15am
paulmoran2
That's the one..icon looks like air-flow lines Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #288551 24th Oct 2014 10:21am
Ah, I though that was for additional demisting for the rear side windows! Whistle Rolling Eyes
Must learn to RTFM Confused Got - 2017 SDV8 Autobiography in Loire Blue
Post #288560 24th Oct 2014 10:43am
paulmoran2
TBH Alan..i only found out by accident Embarassed GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #288561 24th Oct 2014 10:45am
