![]() | Home > Maintenance & Mods (L322) > Service intervals 3.6 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
Every 12 months or upto 18k at most i think... The car will tell you (if you do high milage) when its due a service dependant on your driving style |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1835 ![]() ![]() |
12 months or 15k miles |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
& looking at the pics from the 'Timing Chain / Engine out' thread it's one hell of an auxiliary drive belt.
Not really. Hardest part is getting the cooling fan out, without loosing too much coolant. That said, I have it perfected now, done enough of them |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
If it sounds that easy mikey I'll book you in when I need it doing. That's if a do actually get one. Looked at one today. Depending on figures |
If you fancy the 5 hour drive up the road, feel free |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Is there a major service on the 3.6, like there is on the D3/4 at 160,000km?
No, that's the cambelt and pump belt you're thinking of. Only applies to the V6 cylinder diesels, (D3, D4, RRS) not the TDV8 or S/C models. |
thanks. So its just regular oil and filter changes, no major/expensive service as such? |
There is a big 10yr service but most of the things on it like diff & transfer oils should be done far sooner imho... Think the gearbox is recommended then too??? Again we do ours every 30K rather than leaving it until 100K |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
I noticed that mine had a gearbox & transfer oil change at 35k, now at 65 I am going to get it in. Mine does very little off roading but dragging the tin tent adds work so will get it done Is this where I put the car details and a bit about myself ?........ |
thanks for the replies, good to know. |
Thanks from me too. It's better to spend £££ on oil and a filter now and then than to wait till its too late, then you are changing the oil and filter along with a a major component.
Check them using an aerosol can lid... Take the drain bung out and let a small dribble run into a brightly coloured lid before refitting the bung. Then you can inspect its colour etc and make an informed decision...
