Home > Maintenance & Mods (L322) > Service intervals 3.6
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
What are the intervals for serving a 3.6? Is it 12 months/15000 miles? Like an A and B service. And are there any belts/chains that need replacing at particular mileage/years?
Been using the search option but not got any real pointers on this. Thumbs Up
Post #288767 24th Oct 2014 10:41pm
Every 12 months or upto 18k at most i think... The car will tell you (if you do high milage) when its due a service dependant on your driving style Thumbs Up
So, if you drive it to one extreme it will need servicing every 9k miles and to the other extreme 18K miles...
And NO there are NO belts or chains to service/change in "Normal" use... Thumbs Up
Post #288769 24th Oct 2014 10:52pm
Mikey
12 months or 15k miles Thumbs Up
There is an auxiliary drive belt to replace every 7 years, but no timing belts to worry about Thumbs Up
Post #288774 25th Oct 2014 6:27am
RiccartonRR
& looking at the pics from the 'Timing Chain / Engine out' thread it's one hell of an auxiliary drive belt.
Bet that makes you curse a tad during replacement Big Cry
Post #288782 25th Oct 2014 8:02am
Mikey
Not really. Hardest part is getting the cooling fan out, without loosing too much coolant. That said, I have it perfected now, done enough of them Laughing
Post #288784 25th Oct 2014 8:06am
Lad
If it sounds that easy mikey I'll book you in when I need it doing. That's if a do actually get one. Looked at one today. Depending on figures Very Happy Still having a nagging urge though.......... 5.0!!!!!!! Whistle
Not driven a 5.0, don't really want to, as I'd want one. Laughing
Post #288919 25th Oct 2014 10:52pm
Mikey
If you fancy the 5 hour drive up the road, feel free Thumbs Up
Post #288932 26th Oct 2014 7:01am
rar110
Is there a major service on the 3.6, like there is on the D3/4 at 160,000km?
thanks
Post #289131 27th Oct 2014 9:49am
mzplcg
No, that's the cambelt and pump belt you're thinking of. Only applies to the V6 cylinder diesels, (D3, D4, RRS) not the TDV8 or S/C models. Thumbs Up
Post #289140 27th Oct 2014 10:21am
rar110
thanks. So its just regular oil and filter changes, no major/expensive service as such?
Post #289144 27th Oct 2014 10:49am
There is a big 10yr service but most of the things on it like diff & transfer oils should be done far sooner imho... Think the gearbox is recommended then too??? Again we do ours every 30K rather than leaving it until 100K Thumbs Up
Hope that helps sir... Thumbs Up
Post #289146 27th Oct 2014 11:00am
n1cktdv8
I noticed that mine had a gearbox & transfer oil change at 35k, now at 65 I am going to get it in. Mine does very little off roading but dragging the tin tent adds work so will get it done Is this where I put the car details and a bit about myself ?........
Post #289149 27th Oct 2014 11:16am
rar110
thanks for the replies, good to know.
Post #289154 27th Oct 2014 11:34am
Lad
Thanks from me too. It's better to spend £££ on oil and a filter now and then than to wait till its too late, then you are changing the oil and filter along with a a major component.
When would you recommend the transfer and diff oils?
Post #289298 27th Oct 2014 10:42pm
Check them using an aerosol can lid... Take the drain bung out and let a small dribble run into a brightly coloured lid before refitting the bung. Then you can inspect its colour etc and make an informed decision...
Rear diffs in V8's (including TDV8) condensate terribly and often run out brown & rusty looking putrid oil so may need a double change (or re-checking a month after changing) Thumbs Up
Don't forget the drain plug is a magnet too Thumbs Up
Post #289299 27th Oct 2014 11:02pm
