Home > Technical (L322) > Fuel tank - dodgy diesel
Spartak
United Kingdom 2003 Range Rover Vogue Td6 Barolo Black
Can anyone tell me the easiest, and quickest way to empty my fuel tank. RR Vogue 2003
Post #300093 20th Dec 2014 5:21pm
Park it in Liverpool! Laughing Laughing Laughing
Post #300095 20th Dec 2014 5:25pm
Rolling with laughter Thumbs Up
Post #300096 20th Dec 2014 5:28pm
Laughing very sharp craig.. ... - .- -.
Post #300098 20th Dec 2014 5:39pm
Find someone with test book or IID or faultmate MSV multi vehicle that can activate the intank pump and primary pump. then all you need to do is take the output pipe off the fuel filter and run a pipe into a suitable container.
When you do this be ready to stop the pump at any time as it can flow a good bit of fuel. Trust i filled up a few 20litre tubs when draining mine down Sad
This method gets the tank almost totally bone dry.
If you were closer i could possibly have helped Smile
also i think the hawk diagnostic thing can do the fuel pump activation as well but not 100% sure of that. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #300099 20th Dec 2014 5:44pm
Spartak
Oh dear. Don't know anyone with anything like that
Post #300100 20th Dec 2014 5:46pm
you should be able to drain it from the secondary fuel pump location..this thread is for the replacement of said pump but it will show you how..
http://www.fullfatrr.com/forum/topic12487.html?highlight=pump ... - .- -.
Post #300101 20th Dec 2014 6:03pm
Spartak
Thank you soooooo much
Post #300104 20th Dec 2014 6:09pm
If you haven't got a member locally who can help you can keep cycling the ignition key and that will pump for about 20seconds at a time to drain the tank. Means you don't have to climb under the car and less fuel spilt as well Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #300107 20th Dec 2014 6:22pm
Spartak
Tried that and got it down to quarter of a tank, but cant get anymore out of it that way
Post #300222 21st Dec 2014 12:03pm
Only other way is to get into the tank via the access holes Sad
It may have had some bits in it that have blocked up the in tank pickups as the tank is more like 2 tanks, 1 each side of the rear prop shaft so there is a pump inside the tanks that balances them out.
The gauze on these is quite fine plastic mesh so even funky old diesel can choke them Sad
To get at them you need to get the spare wheel cover out, then undo the two bolts holding the rear parts of the spare wheel straps out.
Then tank the bolts out of the seat lock handles out.
Then you can push the carpet up and see the two access holes.
Start with the one on the left. Mark the access cover and body with some chalk as they only fit one way correctly.
Then remove the 4*10mm nuts and tank the cover off.
Then using a flat head wide screw driver or a drift knock the spinning lock counter clockwise until it's hand tight and then lossen it off by hand he rest of the way.
Then pull the blanking cover off. Be warned they are very stuck so need some force Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #300225 21st Dec 2014 12:34pm
Spartak
Car now all running. Thanks for all the help people Very Happy
Post #300257 21st Dec 2014 5:30pm
Good work fella Smile get a fuel filter on order and change it after this tank full to be on the safe side Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #300264 21st Dec 2014 5:49pm
