Home > Technical (L322) > Fuel tank - dodgy diesel |
Spartak Member Since: 20 Dec 2014 Location: Dunstable Posts: 7 |
20th Dec 2014 5:21pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Park it in Liverpool! |
20th Dec 2014 5:25pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
20th Dec 2014 5:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
very sharp craig.. ... - .- -.
20th Dec 2014 5:39pm |
Find someone with test book or IID or faultmate MSV multi vehicle that can activate the intank pump and primary pump. then all you need to do is take the output pipe off the fuel filter and run a pipe into a suitable container.
20th Dec 2014 5:44pm |
Oh dear. Don't know anyone with anything like that |
20th Dec 2014 5:46pm |
you should be able to drain it from the secondary fuel pump location..this thread is for the replacement of said pump but it will show you how..
20th Dec 2014 6:03pm |
Thank you soooooo much |
20th Dec 2014 6:09pm |
If you haven't got a member locally who can help you can keep cycling the ignition key and that will pump for about 20seconds at a time to drain the tank. Means you don't have to climb under the car and less fuel spilt as well FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
20th Dec 2014 6:22pm |
Tried that and got it down to quarter of a tank, but cant get anymore out of it that way |
21st Dec 2014 12:03pm |
Only other way is to get into the tank via the access holes
21st Dec 2014 12:34pm |
Car now all running. Thanks for all the help people |
21st Dec 2014 5:30pm |
Good work fella get a fuel filter on order and change it after this tank full to be on the safe side FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
21st Dec 2014 5:49pm |
