![]() | Home > Technical (L322) > Fuel tank - dodgy diesel |
Spartak Member Since: 20 Dec 2014 Location: Dunstable Posts: 7 ![]() ![]() ![]() |
Park it in Liverpool! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
Find someone with test book or IID or faultmate MSV multi vehicle that can activate the intank pump and primary pump. then all you need to do is take the output pipe off the fuel filter and run a pipe into a suitable container.
Oh dear. Don't know anyone with anything like that |
you should be able to drain it from the secondary fuel pump location..this thread is for the replacement of said pump but it will show you how..
Thank you soooooo much |
If you haven't got a member locally who can help you can keep cycling the ignition key and that will pump for about 20seconds at a time to drain the tank. Means you don't have to climb under the car and less fuel spilt as well |
Tried that and got it down to quarter of a tank, but cant get anymore out of it that way |
Only other way is to get into the tank via the access holes |
Car now all running. Thanks for all the help people |
Good work fella |
