![]() | Home > Maintenance & Mods (L322) > WARNING change your diff oil!!! |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3945 ![]() ![]() ![]() |
Guys,
Geoff,
As above a supercharger oil it is available from LR iirc so probably worth doing.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
I would look at changing it all asap sir... I advise my customers to do them every 30K and have some now covered over 300k without issue... Not many make it past either 150k or 10yrs without major issues when they are not changed regularly... Also keep an eye on Coolant & Brake fluid... |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 845 ![]() ![]() |
Thanks Craig
fanders Member Since: 10 Jul 2013 Location: Hants, UK Posts: 322 ![]() ![]() ![]() |
Hi,
The correct Diff oils from JLR are around £30 & The transfer box oil is £45ish if that helps sir |
thx Craig
I have done the gearbox on the 4.2 many times to flush the coolant/ATF mix out and I can tell you it is not hard at all. Drain the box, remove filter/oilpan unit, install new filter/oilpan unit, filling. I'd say an hour would normally do it for me and another 30 mins just getting everything ready and tidying up afterwards (a proper workshop doesn't need all that, I was working in our parking garage in the apartment in Nigeria). Note that I had to lie underneath the car and all that and didn't have all the tools (especially filling took some time) so a proper garage should not take that much time I guess.
I'd jet wash the bolts when you get a chance and then cover in penetrating fluid at least a few days before as it does help even just a little bit and then keep spraying them every day before the job is done and it will make your life easier if your diying it and if not just leave it as is 😄😄 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
so a dealer will want money for the fluids
Genuine JLR gearbox service kit for a 3.6 will cost you £260 ish retail... A 4.4 is nearly twice the price! Ouch!!! Takes me around 1.5 hrs on a 2 poster without rushing sir... Hope that helps ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8769 ![]() ![]() ![]() |
pries from dan when I did mine last year:
so we are talking
