![]() | Home > Maintenance & Mods (L322) > 4.2SC - New Oil Filter Housing Assembly needed. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Piece of cake on a TDV8 |
Does the engine oil need to be drained so as to be able to replace the oil filter and the gasket seal?
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
No.....the oil does not need to be drained Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Thanks |
Just found out the gasket seal arrived yday.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
not necessary to do that ryan, but remember to put some new oil on the seal before screwing the filter back on.. ... - .- -.
Thanks Stan, it's a funny looking thing is that seal:
i thought you were changing the seal on the bottom of the oil filter,
It's called a gasket seal. |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
The oil filter can be quite tricky to get access to. I picked up one of these when I changed the oil on mine, great tool had the filter out in seconds. From what I have read the sc has more hoses etc restricting the filter than on mine. But this tool will do the job on a long extension |
The shape of the gasket/ O ring is a tad confusing Stan.
so is the oil leaking from the bottom of the oil filter?
