Home > Maintenance & Mods (L322) > 4.2SC - New Oil Filter Housing Assembly needed.
Page 1 of 3 123>
pld118
After yet more months of investigation, as of 20.03.15, an oil leak has now been deemed attributable to the need for a new oil filter housing assembly. This original post has been edited and the 20 March update further in the thread explains the diagnosis/ need for a new assembly. The rest of the post until that point shows efforts to fix the leak along the way.
Post #312556 14th Feb 2015 9:40am
wealy
Piece of cake on a TDV8
Post #312591 14th Feb 2015 2:09pm
pld118
Does the engine oil need to be drained so as to be able to replace the oil filter and the gasket seal?
I've just paid a MD to oil service the car which beforehand had an oil leak from an oil filter housing gasket seal which is still leaking because they didn't have a replacement seal.
Workshop manual on the oil and filter change procedure link:
http://workshop-manuals.com/landrover/rang...page_1534/
Post #312722 15th Feb 2015 7:22am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
No.....the oil does not need to be drained Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #312725 15th Feb 2015 8:18am
pld118
Thanks
Post #312728 15th Feb 2015 8:27am
pld118
Just found out the gasket seal arrived yday.
For just changing the oil filter to replace a seal, would I need to disconnect the battery ground (earth) cable?
Post #312749 15th Feb 2015 10:56am
not necessary to do that ryan, but remember to put some new oil on the seal before screwing the filter back on.. ... - .- -.
Post #312753 15th Feb 2015 11:09am
pld118
Thanks Stan, it's a funny looking thing is that seal:
Post #312754 15th Feb 2015 11:18am
i thought you were changing the seal on the bottom of the oil filter,
whats that seal for then? ... - .- -.
Post #312758 15th Feb 2015 11:38am
pld118
It's called a gasket seal.
Post #312762 15th Feb 2015 11:58am
Thumbs Up ... - .- -.
Post #312765 15th Feb 2015 12:13pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
The oil filter can be quite tricky to get access to. I picked up one of these when I changed the oil on mine, great tool had the filter out in seconds. From what I have read the sc has more hoses etc restricting the filter than on mine. But this tool will do the job on a long extension Thumbs Up
 Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #312769 15th Feb 2015 12:20pm
pld118
Post #312771 15th Feb 2015 12:27pm
pld118
The shape of the gasket/ O ring is a tad confusing Stan.
Look at the figure 8 gasket I've photographed, part number LVF500010.
And yet Microcat shows a singular O ring (6840) for the same part number?
Post #312794 15th Feb 2015 2:41pm
so is the oil leaking from the bottom of the oil filter?
if so then it should only be the one round seal that maybe is twisted or not seated correctly .. ... - .- -.
Post #312802 15th Feb 2015 3:32pm
Page 1 of 3 123>
