Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option!
Page 3 of 6 <123456>
thats cheap, good find sir,
Post #314595 24th Feb 2015 12:28pm
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Does anyone think it is worth changing this seal while I am doing the job?
I can't actually see anything wrong with it, nor do I know if a new one is easy to fit but they work out at £7 inc postage.
Post #314639 24th Feb 2015 6:03pm
No Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #314640 24th Feb 2015 6:13pm
scwilson
Ok - do it once etc. I just didn't want to find out something else perishes a few months down the line and have to take it all off again.
I'll leave this part then.
Post #314641 24th Feb 2015 6:35pm
If it ain't broke............... Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #314642 24th Feb 2015 6:42pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have a new motor/pump unit and a new wiper arm and jets but the water still takes ages to start and then is more of a flow than a spray. Can someone please advise (with pics if possible) where to try and insert a non return valve if this is likely to solve the problem. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #314644 24th Feb 2015 6:57pm
scwilson
Not sure on this non-return valve but even on my rear washer (albeit leaking at the moment), it flows out - doesn't spray, mine is not new, it's the original.
Post #314739 25th Feb 2015 12:08pm
bebechoon
France
I did alanm_3’s “cheaper” rear washer leak repair today and I shall be eternally grateful to him for having devised this clever mod. Even taking things very, very slowly and carefully, and losing a lot of time searching in my various boxes for suitable screws, I had the whole thing done in about an hour and a half.
The rear washer now works a treat … apart from the fact that the tiny nipple/grommet housed in the wiper arm which provides the seal between the wiper washer outlet tube and the arm itself seems to be Censored and water gushes out from there now Big Cry – but happily onto the outside of the screen Thumbs Up So I guess I now have to buy a new wiper arm with this bit in it …
So, many thanks alanm_3, and if anyone else is thinking of trying this mod but hesitating, then I’d say give it a go, if I can do it, so can you! It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 8 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #315567 1st Mar 2015 2:38pm
Appreciate your kind comments. Glad it did the trick for you Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #315578 1st Mar 2015 4:11pm
n1cktdv8
+1 of thanks - top drawer, £5.00 delivered to the door. Nice easy fix and working perfectly now Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #315583 1st Mar 2015 4:52pm
scwilson
I have yet to do mine but this is encouraging. I think I am most worried about getting the trim off and not snapping anything.
Post #315615 1st Mar 2015 7:43pm
bebechoon
France
I was too, so I understand your concern.
I’d previously taken the trim off before knowing about this post (very brave of me!) and indeed I broke one of the plastic fixing lugs (can’t think of a better word) because I didn't know in which direction to pull, or if there was anything else involved. However, follow the advice here and pull it off smartly, perpendicular to how it fits in, ignore the screeching noises, and off it comes! (Quite satisfying, actually!)
And even having broken one (or two …or three …) lugs, just a couple of the remaining ones should be enough to secure it. Worst case? Buy a new finisher … which is probably what I shall be doing – I’m just waiting to hear from Ducky Dan.
Go for it, scwilson - and good luck! It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
Previous:
Disco II
Post #315622 1st Mar 2015 8:15pm
Yep, think mine has a couple left now! Still holds on fine though! There is nothing that can't be fixed with a hammer😜😜
Post #315638 1st Mar 2015 10:21pm
mike whiskey
United Kingdom 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Thanks for this tip. Guess what I'm going to be doing in the near future! Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2, FFRR. D3, Freelander 2 and now back in FFRR.
Yes I'm a masochist....
Post #374097 25th Feb 2016 2:10pm
rangie47
Tried this on mine .but still leaks Big Cry
There are groves on the spline,think this is the problem .
So going to bite the bullet and buy new Big Cry 2007 tdv8 se ,stornaway grey
Post #374115 25th Feb 2016 4:38pm
