Home > Maintenance & Mods (L322) > angel eye fogs/drls
Page 3 of 7 <1234567>
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Those look great stan Thumbs Up
good write up well done Bow down Bow down Bow down
Post #339662 29th Jul 2015 6:03am
ta greg Thumbs Up ... - .- -.
Post #339664 29th Jul 2015 7:59am
gregdav
Can you wikify yourself stan.
I think it's worth it Very Happy Thumbs Up
Post #339667 29th Jul 2015 8:29am
supershuttle
Stan, despite my earlier jibe re the strip on the bonnet (still think that's tacky BTW) these look absolutely great and I imagine that the fog light part is pretty good when connected. I currently drive round with my sidelights on as I think the little lights in the headlights should be DRLs but these looks like I should have them. You mention a DRL switch so are they on all the time with the switch being an over ride to turn them off or do you just switch em on and off? Geoff
Post #339674 29th Jul 2015 8:57am
when the ignition is switched on the drls come on automatically via the switch, [its a little box actually] .....when the side lights are switched on the drls stay on , which is good for dusk times when headlight would be to much...
turn the headlights on and the drls automatically go off...
i've had this little box for about eight years now so i dont know if this one is still available but i've seen others on ebay that will do the job..
@greg...might do that Thumbs Up ... - .- -.
Post #339675 29th Jul 2015 9:11am
proser
This can easily be done with a 5 pin (switch over) relay. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #339682 29th Jul 2015 9:32am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
^^ can you explain how its done? Do you have to splice into the stock harness or are you just replacing a relay in the fuse box with another one? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #339726 29th Jul 2015 2:00pm
i managed to temporally wire up the cob projetcors and they to are very bright..i dont think there's much 'forward' light though but i'll have a go when its dark..
drls and cob centres,
dipped beam and cob centres, drls off,
Post #339733 29th Jul 2015 3:45pm
Bow down Bow down Bow down Thumbs Up
Post #339804 29th Jul 2015 9:41pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
They look good Stan Thumbs Up
I like the idea but I'm not sure about fitting myself, mainly the wiring part. Do you use your lights on auto?
Post #339806 29th Jul 2015 9:47pm
@craig-meister Wink
@fish, dont use auto.... ... - .- -.
Post #339810 29th Jul 2015 10:01pm
@ horse 86
New separate 5pin relay required located in engine bay connected to drl's as follows:-
Connect Ignition source cable with inline 5A fuse to terminal 30 of relay.
Connect cable to drl's to terminal 87a of relay.
Drl's earthed locally to bodywork.
Splice a cable into Main beam (or Dip Beam if you prefer) cable behind either headlight and run cable to connect with terminal 86 of relay.
Connect terminal 85 of relay to bodywork earth.
No cables connect to terminal 87.
This arrangement will result in the drl's coming on when the ignition is switched on and switch off when either main beam or dipped beam headlights are selected depending on which wire you spliced into behind the headlights.
Don't forget led's are voltage sensitive and need to be connected right way round, if they don't light first time reverse their connections.
Usually a 30A 5pin 12V relay is the easiest to source but a lower rating would be adequate.
5A cable is adequate but I have to admit I used standard twin speaker wire contained in 10mm convoluted cable sheathing when I did mine. More than adequate and I just happened to have a lot of it lying around. Thumbs Up Smile
Post #339887 30th Jul 2015 10:57am
proser
Cheers nicedayforit
Missed the reply to my post about a 5pin relay. Regards
Mark
2012 Westminster
Post #339888 30th Jul 2015 11:04am
Post #339889 30th Jul 2015 11:12am
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Great write-up again David Thumbs Up And thank you Stan for all the photo's. Thumbs Up
Will come in handy when I install my DRLS. I think this is a great feature to add to my car. I just ordered the lights and will install them when I'm back from holidays.
Stan, do you think the center lights of the new unit are bright enough to replace the standard fog lights? 2002 L322 V8
Post #339893 30th Jul 2015 11:29am
