Home > General > How happy are you with your 2011 TDV8?
How has ownership of your 2011 4.4 TDV8 been so far ?
Faultless in all apsects.
25%
 25%  [6]
Some minor issues all sorted.
29%
 29%  [7]
Some minor issues not all sorted.
16%
 16%  [4]
Some major issues all sorted.
16%
 16%  [4]
Some major issues not all sorted.
0%
 0%  [0]
Major and minor issues all sorted.
8%
 8%  [2]
Major and minor issues not all sorted.
4%
 4%  [1]
Total Votes: 24
Benfelrr
United Kingdom 2007 Range Rover Vogue TDV8 Tonga Green
Hi, hope this is OK, looking at a TDV8 again, 4.4 this time. Read plenty on it but wondered if I could ask if any owners would give a quick click to the pole, interested to see how they are rated by their owners. Shocked 2011 Range Rover Vogue 4.4 TDV8
2003 VW Golf V6 4motion
2001 Range Rover Vogue 4.6
1982 Range Rover in VOGUE
1990 Range Rover Vogue SE
2007 Audi A6 Avant Le Mans Quattro S-Line 3.0 TDI
2007 Skoda Ovtavia 2.0 TDI L&K
2007 GSX-R 750 K7
Post #341928 11th Aug 2015 10:46pm
A couple of silly issues with mine.
A temperature probe in the manifold (which created an EGR issue) sorted by MD for £120
Front shocker wire broke at 21k miles Rolling Eyes fixed by me in under an hour!
an engine oil leak. 2 hours and a 20p seal (pipe the other end of the EGR unit from the oil filter) common issue... Rolling Eyes
Been about as reliable as my other 2yr old FF’s I’ve owned in the past... That said, i did look at a good few before buying this one and there are plenty of more troublesome ones around than mine... Whistle Rolling Eyes Whistle
Post #341946 12th Aug 2015 12:30am
Oh and absolutely streets ahead of my 4.2 sc & both my 3.0 & 3.6 derv models. SUCH a leap forward in technology, sound/quiet & comfort levels Bow down Thumbs Up
Post #341947 12th Aug 2015 12:34am
Herdwick
I put for minor issues, I have had 4 x new starter motors. (A common fault) and an intercooler pipe split. A modification to the air con pipes seems to have helped to cure the problems with the starter motor,
Apart from that it has been a great car.
I will be sorry to see it go.
Post #341995 12th Aug 2015 10:53am
Benfelrr
Thanks guys , much appreciated. ! I Looked at the car this morning, it is pretty mint! 2011 Range Rover Vogue 4.4 TDV8
2007 GSX-R 750 K7
Post #342028 12th Aug 2015 1:22pm
Forgot about the intercooler pipe i replaced too Embarassed Embarassed Embarassed
My list above obviously does NOT include what the original owner had carried out! My car was owned by a long term well respected client of LR (been a repeat new car customer for many many years) so, he had every modification/update done by his MD at service dates without asking (is my understanding) meaning, this car has had everything thrown at it by the JLR dealer network to keep a “good customer” sweet!
Well worth bearing in mind whilst searching!
Post #342035 12th Aug 2015 1:38pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Mine is a 2011MY but is the 4.4.
Ex LR vehicle.
Water leaks into rear compartment.
Front shocker wiring broken on both sides.
Trim on tailgate window rusting, replaced.
Went into limp mode, sensor changed but it took them a week to find it.
Air con leaked, pipe replaced.
New starter motor.
New front brake pipes.
All fixed under warranty, superb vehicle.
Ian
Post #342041 12th Aug 2015 2:02pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Fixed - rear and side window trim corrosion; hesitation (software reflash); starter motor; foam filler block in door shut (twice).
Not fixed (and not likely to be, now out of warranty) - regular and infuriating low battery warning.
Post #342072 12th Aug 2015 4:43pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
I get frequent low battery warnings on my Mini Cooper S. Apparently, it's because I don't drive it enough. It does lots of short journeys with SWMBO. Never had it on the RR or RRS, but only do longer journeys in those cars.
Post #342083 12th Aug 2015 5:31pm
verydisco
Hi,
on my 2012 Vogue model:
Light in sunvisor not working, fixed thanks to Craig
Water in side repeater, replaced
Front passenger side tyre shows more wear than others.
Nothing major, really.
such a smooth ride and comfort is one step up 3.6L TDV8, and I won't even compare it to 3.0L Straight 6 ones I have both owned.
fuel economy is great too Wink l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #342086 12th Aug 2015 5:38pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
I have only had my car for 6 weeks, and after my TD6 it is a revelation. Lots of power, smooth, quiet. Nothing has gone wrong so far, but talking to the previous owner, he had to have the turbos replaced under warranty. and had an electrical problem with the suspension sorted. 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #342103 12th Aug 2015 7:21pm
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
I've been thinking about upgrading to one of these but my 2002 4.4 petrol still keeping running sweetly. Seems like there have been quite a few problems so maybe I'll run my V8 into the ground before I change.
Post #342131 12th Aug 2015 9:30pm
L19 MUD
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I'm in a similar place with my 2002 V8...but took the plunge and put it on ebay now so looks like a 3.6 or 4.4 TDv8 will be (hopefully) imminent
Post #342236 13th Aug 2015 1:30pm
Ahh, that may be tempting fate sir Whistle Whistle Whistle
Post #342349 13th Aug 2015 11:55pm
Baltic Blue
Had. 4 rr over last 30years. Started with 2.5vm diesel so , then 2.5td P38, just traded up from Td6 Vogue.I have kept each one until 100k miles or 9years. Just hoping to do same, but not happy just spotted first signs of corrosion on upper tailgate bottom right corner. Anyone made corrosion warranty claim?
Post #342380 14th Aug 2015 8:59am
