![]() | Home > General > How happy are you with your 2011 TDV8? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16396 ![]() ![]() ![]() |
A couple of silly issues with mine.
Oh and absolutely streets ahead of my 4.2 sc & both my 3.0 & 3.6 derv models. SUCH a leap forward in technology, sound/quiet & comfort levels |
Herdwick Member Since: 05 May 2010 Location: Lake District, Cumbria. Posts: 36 ![]() ![]() ![]() |
I put for minor issues, I have had 4 x new starter motors. (A common fault) and an intercooler pipe split. A modification to the air con pipes seems to have helped to cure the problems with the starter motor,
Benfelrr Member Since: 27 May 2012 Location: Wiltshire Posts: 301 ![]() ![]() ![]() |
Thanks guys , much appreciated. ! I Looked at the car this morning, it is pretty mint! 2011 Range Rover Vogue 4.4 TDV8
Forgot about the intercooler pipe i replaced too |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Mine is a 2011MY but is the 4.4.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Fixed - rear and side window trim corrosion; hesitation (software reflash); starter motor; foam filler block in door shut (twice).
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1085 ![]() ![]() ![]() |
I get frequent low battery warnings on my Mini Cooper S. Apparently, it's because I don't drive it enough. It does lots of short journeys with SWMBO. Never had it on the RR or RRS, but only do longer journeys in those cars. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi,
scuddriver Member Since: 12 Feb 2015 Location: Dunbar Posts: 140 ![]() ![]() ![]() |
I have only had my car for 6 weeks, and after my TD6 it is a revelation. Lots of power, smooth, quiet. Nothing has gone wrong so far, but talking to the previous owner, he had to have the turbos replaced under warranty. and had an electrical problem with the suspension sorted. 2011 Vogue TDV8 4.4
Bagus Member Since: 15 Apr 2014 Location: London Posts: 202 ![]() ![]() ![]() |
I've been thinking about upgrading to one of these but my 2002 4.4 petrol still keeping running sweetly. Seems like there have been quite a few problems so maybe I'll run my V8 into the ground before I change. |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
I'm in a similar place with my 2002 V8...but took the plunge and put it on ebay now so looks like a 3.6 or 4.4 TDv8 will be (hopefully) imminent |
Ahh, that may be tempting fate sir ![]() ![]() ![]() |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3866 ![]() ![]() ![]() |
Had. 4 rr over last 30years. Started with 2.5vm diesel so , then 2.5td P38, just traded up from Td6 Vogue.I have kept each one until 100k miles or 9years. Just hoping to do same, but not happy just spotted first signs of corrosion on upper tailgate bottom right corner. Anyone made corrosion warranty claim? |
