![]() | Home > Wheels & Tyres > Front Tyre Wear 2012 Westminster TDV8. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
i must be reading it wrong then...are you saying to 'turn' the tyre on the rim so that the worn outside edge is on the inside then because the tyre is probably an asymmetrical tyre then you cant do that...
Effectively the wheel stays where it is but the tyres get swapped at the front. This means the worn outters become worn inners 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
if the nsf tyre/wheel goes to the osf , why would you take it off the rim?
That's it Stout 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
...but you can not do that Will..... |
It could be an issue with some tyres but if they are pointing forward as they should be how can it be an issue?
i still say that if the tyre has the word 'outside' on the side of the tyre then it must be fitted that in that way...
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
correct me if i am wrong but i think you are trying to say
I'll look at my vreds when I get home but I'm positive there is no outside or inside marker on them just a rotational requirement. As long as the rotation is correct it doesn't matter what wheel or side they are on.
This should help us all...
I get what Stan is on about. Wifey's XF has both a rotational requirement AND they all have the word OUTSIDE on the outer facing side wall. They cannot be swapped from side to side, only front to back. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8094 ![]() ![]() ![]() |
Vreds are directional but symmetrical |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 188 ![]() ![]() ![]() |
Nerdy I know but I bought a digital tread depth gauge. The readings are quite useful.
