![]() | Home > Maintenance & Mods (L322) > WARNING change your diff oil!!! |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Are you sure the car is completely level? Even if the suspension is a bit low at the back it would do it. |
Did it exactly same a last time. Back end was raised via jacks and axle stands! |
Concerns now allayed:
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
I did my front and rear Diffs last week at 61k. The front wasn't too bad but the back stank awful and was full of glitter. Is this normal or is it a sign of excessive wear?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35821 ![]() ![]() |
the only way to find out is to check it in a few months time...if its gone glittery then you might have a problem, if clear then its ok .. ... - .- -.
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 ![]() ![]() ![]() |
Oil in a Defender? ![]() ................most of it leaks out! |
The purpose of a good magentic drain plug is that metal particles floating around can stick to it and can save on wear and tear that such particles might cause. You can buy so called stronger magnetic drain plugs from the likes of Opie Oils et al. I replaced the drain plugs with a new LR supplied one but others on the forum don't always bother replacing the plug. The oil in the rear diff stinks and has done so on the two occasions I've done it. The first time, I changed the rear diff oil on our 4.2SC @ 88k miles/ 7 years old. It was a horrible, dark glossy brown colour. No water mixed in and no metal particles floating around, nor accumulated on the magentic drain plug. The second time was on our 4.4TDV8 @ 30k miles. It was almost the colour of new oil but a tad darker. No water mixed in there and no particles accumulated on the drain plug magnet, although there were some very fine/ very early signs of metal particles within the drained fluid. People say that if the Diff has been affected by wear, symptoms can also include a metallic whine noise, which Ive never experienced. ![]() |
Thanks PDL118. My diff runs very smooth and is quiet, I was just concerned about the glitter which was all the way through the oil. I wish I had taken a pic now to put it on here. I'm going to change it again in a few thousand mile to see how it looks. If it's still same I will strip it down and inspect the gears. |
Presumably the L405 Diff oil needs to be changed at similar intervals as the L322?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Just reading this, can anyone recommend an Indy in the South East that can do diffs TC and trans fluids?
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 358 ![]() ![]() ![]() |
Hey Fella - I cant stress how simple it is to do: Front & Rear Diff oils - total time is about 20 mins max each - oil costs around £19.00 per litre ( only use Castrol Syntrax Long Life 75W90 Synthetic Gear Oil - no other make ! Transfer box - again this is 20 mins top - so easy I got the wife to do it last time ! Going to your question: As its so simple to do and as LR recommends every 75,000 miles - I do ours cars very 20,000 miles - its a no brainier and costs so little to do. JUST ENSURE you only use NEW copper LR washers - especially of the Transfer box Drain and Fill plugs - and TORQUE to correct settings. NOTE: and this is a big note - ALWAYS undo the FILL PLUG first BEFORE the DRAIN PLUG - if for any reason the FILL PLUG will not undo then at least you still have the oil in the unit and not all is lost ! That said a well maintained RR is a pleasure to work on. Another word of caution - NEVER OVER FILL ANYTHING as this will lead to catastrophic damage. if in doubt always get the fluid levels in writing from your LR parts department then you know that's the bible. If anyone reading this about the TRANSFER BOX OIL: ONLY USE LR IYK500010 No other oil ever use in the Transfer Box - its a very special thin grade oil - I change ours every 20,000 miles - its so easy to do . |
EmiratesA380, great info! I am contemplating doing this myself so great to get an idea of what's involved - and some excellent tips too.
Hey Greg
