Home > Maintenance & Mods (L322) > Restricted Performance, White Smoke, Lumpy idle.
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
So my 2010MY 3.6TDV8 decided to act funny today.
While going into a carpark I noticed it whistling / high pitched noise that went in time with revs. When leaving the carpark the noise dissapeared, but things were not right, the car went into restricted performance mode and i couldnt go above 30 km/h , absolutely no acceleration and pouring white / grey smoke out of the back (funnily enough its mostly the right hand exhaust, very little from the left)
Restarted the car and the same thing , also upon restarting it cut out , tried a few more times and its cutting out and throwing up weird errors and stuff like my surround cameras and radio not working (although the battery may be low from too many starts)
have had it towed to a dealer but it may be a few days before they can take a look Sad .
IIDTool gave the error P010C-21(2Cool , later changes to P010C-21(2c)
theres 58000~ miles on it.
I checked the upper intercooler hoses, they seem intact , although the right hand one (right hand facing the engine bay , Passenger side of an RHD car) seems quite soft whereas the left is pretty solid and cant be squeezed.
Any idea what hardship im in for ? Current Vehicles :
L322 2010MY TDV8 Autobiography
BMW E38 735i
BMW E63 645ci
Post #387394 16th May 2016 6:14pm
dingg1
http://www.fullfatrr.com/forum/topic27781.html
hope not for your wallets sake
good luck
Post #387398 16th May 2016 6:34pm
Mikey
Classic turbo failure Neutral
Post #387399 16th May 2016 6:35pm
Eric Cartman
So it was the right hand turbo failed ,
They fitted it and discovered that the crank case breather was blocked so changed
Then the left hand turbo failed.
Theyve had the car 2 weeks , have been told 5 times it would be ready and it hasnt , supposed to go pick it up monday with a lovely €5k + bill.
But theyre going to to a mini valet for free so apparantly this is all fine Rolling Eyes Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #388939 27th May 2016 6:21pm
And they will wash it and scratch/swirl the paintwork for you as well Twisted Evil .
Post #388941 27th May 2016 6:30pm
Eric Cartman
I wouldnt expect any less, does anyone know if garrett has a warranty on the new turbos ? Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #388943 27th May 2016 6:35pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Hhhmmm after reading this I thought I'd search to see where the breather is to check mine. But doing a search it looks like they may not have one.
http://www.fullfatrr.com/forum/topic29087....e+breather
Is this correct that they may not have one?
But if they do, where is it, and is it easy to get to?
Post #389034 28th May 2016 8:22am
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
3.6 has a breather/separator.
It's behind the oil filter/cooler assembly.
It operates under vacuum from the driver side turbo, with liquid draining back to the sump
Post #389046 28th May 2016 9:24am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Hmm, I'm booked in for a service next week, anyone got a link for the tdv8 breather?
Post #389054 28th May 2016 10:13am
cheezels
There is no mention of this being a service item, but I will be changing mine out soon as I've suspected this may be a cause for the driver side turbo failure.
Part number is - oil separator LR002343
Below is a bit of a mud map of how I interpret the Charge air air, EGR system and crankcase ventillation system to be.
A drawing of the breather system is in the manual, around page 1600. (Can't seem to upload it just now)
Mad
I'm interested if the OP had pictures of his blocked breather, or a reason why the passenger turbo failed as well??
Post #389055 28th May 2016 10:36am
Mr Tee
Thanks for that, will ask Dan for a price
Post #389069 28th May 2016 12:02pm
cheezels
No worries
Interested to see how you get on.
If you could ask for the old one, maybe, to see how it's put together/stripped for cleaning etc
I think they're about 50 of her majesty's pounds
Post #389073 28th May 2016 12:37pm
Mr Tee
Know the mechanic well, shouldn't be a problem
Post #389074 28th May 2016 12:59pm
cheezels
That's awesome.
Look forward to any feedback
Post #389076 28th May 2016 1:23pm
cheezels
and hopefully here is the drawing from the manual
Post #389170 29th May 2016 5:09am
