![]() | Home > Maintenance & Mods (L322) > HVAC fan fail |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I would be doubly certain before seeking to replace the fan/motor. Not sure where the connector block is for it, but would see if the fan runs straight from a battery. The fix to replace is not for the faint hearted - either whole dash off, or judicious cutting of the inner dash to get the fan out. There is a howto on here on this latter one.
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I replaced the FSR and ... nothing. So I doubt the new one died in a few seconds. It also gets warm, so I guess there's power to it. I'm going to check fuses again, this time with a meter rather than just visually. If anyone knows where the connectors are, please tell me! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
Can you not remove the pollen filter housing complete and then see the ends of the fan blade assemblies.
Looks like connectors C0056(motor)/C2281(motor control unit) are hidden behind the centre console (below the computer screen)
I'll certainly try taking the filter housing out. Seems like an easier route to see what's happening. |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 ![]() ![]() ![]() |
With a bit long arms and fingers, you can reach the fan after removing the pollen filter housing, just two nuts, the bonnet gasket and the whole housing slides out. Recirc need to be OFF.
Ah yes, I saw that video when I was searching for ideas! I'll take a look, at least I can establish if it's tight bearings. The squeaking would suggest that. |
Mine didn't squeak at all but the squeak is a quite clear indication that the bearings are finished... "Plentraktoren/Garden tractor": 2008 L322 TDV8
I just looked at RAVE for the official method. Good grief - take out HOW MUCH STUFF?
No visible parts are modified, some airducts and other parts are cut, see here: http://www.fullfatrr.com/forum/topic14961-83.html "Plentraktoren/Garden tractor": 2008 L322 TDV8
OK, brave pills taken and dash top off. The fan has clearly almost seized, and the right side blades have disintegrated! I managed to pull out the debris, but the fan still won't turn easily.
You have to consider the amount of work vs. fan cost. I used about 4.5 hours of effective work time, the local garage esimate 11.4 hours... I would put in a new one... "Plentraktoren/Garden tractor": 2008 L322 TDV8
OK, progress. The dash didn't take long to remove once I'd figured out the clips for the vents, cutting some of the under-dash plastic away was a few minutes with a dremel and cut-off disc, and what was left of the old fan came out pretty quickly. Lots of skinned knuckles getting the broken fan blades out though! I've ordered a used fan from eBay - £15, so if I break it fitting it there's no great loss.
Well done mr_spock, looking forward to the refit |
