![]() | Home > In Car Electronics (L322) > Reverse camera repair / upgrade |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
Outstanding thanks Stu |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 ![]() ![]() ![]() |
Glad that's helped/ cleared it up, word of caution make sure no stray strands of braid don't get caught in positive connection that would cause havoc I'm sure. Perhaps strip back longer than I've shown.
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 ![]() ![]() ![]() |
Frustration here |
If the camera worked when you connected a power source (i.e. It overrode screen image to give rear view) then I suppose you could pick up a feed for it from reversing lights perhaps.
Thanks.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Has anyone fitted a new/cheapo camera that doesn't have the reverse markers on the lense? It's beginning to bug me having them offset on the screen and I'm looking to see how I can replace the existing camera with one that has no marker lines. Is this where I put the car details and a bit about myself ?........ |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Sorry to jump in on the thread n1cktdv8 but can i also ask if alongside the reversing lines not being there does anyone elses replacement camera seem to be zoomed in too so things seem a lot closer than they actually are and closer then they would be on the original one?? And if so is there a setting somewhere to change this? Current 2007 TDV8 Vogue Buckingham Blue |
I seem to think there was a green wire that you could snip to disable the lines, it was a loop I think. I rotated the camera in the housing until the lines seemed to line up on mine and it's pretty good actually. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 ![]() ![]() ![]() |
I think there's a setting in the "secret menu" to change the camera view, I'm pretty sure I changed it when I replaced my camera, having said that, I think I changed my camera twice as I found the view better from a camera I removed from another vehicle and was just lying around. http://www.fullfatrr.com/forum/topic28741.html |
Thanks i will have a look at that and see if therea anything to adjust! I was looking more to zoom out so i could see then end of the rear bumper on mine so it would give me an idea of space available behind as its so zoomed in now you cant tell! If this doesn't work i will have a look at the wider angle ones and see if the work better! |
Miggit - that is a consideration for me presently. I've never been 100% happy with the camera, or the replacement. I am thinking of ordering another Chinese fleabay £5 special and hopefully find this green wire to cut.
