Home > In Car Electronics (L322) > Reverse camera repair / upgrade |
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 |
Outstanding thanks Stu |
27th Oct 2016 8:56pm |
stucart Member Since: 03 Jul 2016 Location: Staffordshire Posts: 84 |
Glad that's helped/ cleared it up, word of caution make sure no stray strands of braid don't get caught in positive connection that would cause havoc I'm sure. Perhaps strip back longer than I've shown.
27th Oct 2016 9:06pm |
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 |
Frustration here I got the new camera, made up the loom perfectly and plugged it in - still a black screen.
4th Nov 2016 6:42pm |
If the camera worked when you connected a power source (i.e. It overrode screen image to give rear view) then I suppose you could pick up a feed for it from reversing lights perhaps.
6th Nov 2016 7:42pm |
Thanks.
6th Nov 2016 8:22pm |
glad you got it sorted, all be it with some frustration |
7th Nov 2016 2:02pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Has anyone fitted a new/cheapo camera that doesn't have the reverse markers on the lense? It's beginning to bug me having them offset on the screen and I'm looking to see how I can replace the existing camera with one that has no marker lines. Is this where I put the car details and a bit about myself ?........ |
5th Jun 2017 9:33am |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Sorry to jump in on the thread n1cktdv8 but can i also ask if alongside the reversing lines not being there does anyone elses replacement camera seem to be zoomed in too so things seem a lot closer than they actually are and closer then they would be on the original one?? And if so is there a setting somewhere to change this? Current 2007 TDV8 Vogue Buckingham Blue |
5th Jun 2017 9:46am |
I seem to think there was a green wire that you could snip to disable the lines, it was a loop I think. I rotated the camera in the housing until the lines seemed to line up on mine and it's pretty good actually. |
5th Jun 2017 9:05pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
^ a lot of the Ping Pong cameras have a looped wire at the plug end which when cut turns off the reversing grid.. but if there is no loop then you can't turn it off...
6th Jun 2017 5:49am |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I think there's a setting in the "secret menu" to change the camera view, I'm pretty sure I changed it when I replaced my camera, having said that, I think I changed my camera twice as I found the view better from a camera I removed from another vehicle and was just lying around. http://www.fullfatrr.com/forum/topic28741.html |
6th Jun 2017 6:56pm |
Thanks i will have a look at that and see if therea anything to adjust! I was looking more to zoom out so i could see then end of the rear bumper on mine so it would give me an idea of space available behind as its so zoomed in now you cant tell! If this doesn't work i will have a look at the wider angle ones and see if the work better! Current 2007 TDV8 Vogue Buckingham Blue |
6th Jun 2017 7:25pm |
There's going to be tears before bedtime If your camera is a factory fit, under the spoiler..... it doesn't matter how much you zoom in and out, you are never going to see the bumper... unless it's fallen off Because the camera is mounted 18" in from the rear the tailgate obstructs any and all views of the bumper. If you want to see the bumper you'll need to fit another camera... like the BMW X5 ones that replace a number plate lamp Yesterday I couldn't spell Engineer... Today I are one!
7th Jun 2017 7:09am |
Miggit - that is a consideration for me presently. I've never been 100% happy with the camera, or the replacement. I am thinking of ordering another Chinese fleabay £5 special and hopefully find this green wire to cut.
9th Jun 2017 12:04pm |
