![]() | Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35852 ![]() ![]() |
according to the WM you can disconnect this pipe to drain the oil rather than using a vacuum..
Macca314 Member Since: 12 Feb 2017 Location: Lincolnshire Posts: 23 ![]() ![]() ![]() |
Thankyou. I looked at that shall give that ago.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
If you do drain the oil this way, please take some photos and add any tips to this post.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
I have recently bought a 'Draper Expert' vacuum pump from machine mart. 95.00. Its a 10 litre capacity manual or pneumatic and is so easy to use. Plugged in my compressor and away it went - extracted 9.5 litres i about 2 mins. An oil change on my 4.4TDV8 took 10 mins and was so simple.
Hi Ajac
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Any reason 3k oil changes? Seems pretty frequent Cheers, Greg
Macca PM sent but essentially the Draper comes with a flexi tube that fits snuggly over the (6mm?) engine outlet.
A nice treat for your 4.4 !
... and having serviced Marine diesels for quite a few years with no sump drains (normal for marine), I can say that the right oil extractor is worth it's weight. So if there is one that works well stick to that.
MrChubba Member Since: 03 Dec 2017 Location: Penrith, Cumbria Posts: 4 ![]() ![]() ![]() |
Hi Ajac,
My job for today, but note these pictures relate to the 4.4tdv8, as per the original thread title.
now I know where to come for my next oil change |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Mike, I see your oil level is at "max" and the engine temp. is just warm, when engine reaches full working temperature oil level is going to be two maybe 3 nocis over "max". get the engine to working temp. and check the oil level ( wait minimum of 25~30 sec. for level to give right reading).
Cheers Nino,
