Home > Maintenance & Mods (L322) > DPF regeneration |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
gonna_go_double_r
3rd Jul 2017 7:57am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
35 mins all in, 15/20 mins on A1/A1m, then 20ish on A61, absolutely horrible flogging the engine like that! But definitely not speed but revs required! Current: TDV8 (3.6) RRS HSE
3rd Jul 2017 9:19am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Ok did mine tonight on an M1 run. Wasn't midnight though nino.
3rd Jul 2017 11:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34936 |
you don't have to rag the engine to get rid of the dpf warning, a steady 50mph for approx 20 mins will do it.....that worked for me... ... - .- -.
4th Jul 2017 8:36am |
My turn of phrase maybe not the best Stan, but to me doing 2.5/3k revs is ragging the engine! In the 4.4. I was only doing 55/60 mph in lower gears. Very uncomfortable process Current: TDV8 (3.6) RRS HSE
4th Jul 2017 10:19am |
thats why the second turbo gets gunked up with oil and hence the drain valve modification...
4th Jul 2017 10:41am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1342 |
I think the handbook says that a period of driving at about 55 - 60 is the way to clean the DPF, rather than holding the revs high. I have oil seepage from one of my turbos, but no smoke, presumably because on Scottish A roads one has opportunities to get revs above 2,500 when overtaking after having been stuck behind slow moving traffic. Only Range Rovers since 1988 |
4th Jul 2017 1:03pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
I have sent a PM to the LR crc account asking for the technical support department to confirm the best way to regen the DPF.
4th Jul 2017 2:25pm |
This is what the owners manual says:
4th Jul 2017 2:39pm |
so my DPF light came on again - it's only been 6 weeks (see above) since last DPF blast....
Anyone know a bit more about this? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
22nd Jul 2017 2:21pm |
what does a RED DPF actually signify?
22nd Jul 2017 2:44pm |
to clarify, you do not have to drive in sport mode or high revs to regenerate the dpf, just a steady drive at 50mph for approx 20 minutes... ... - .- -.
22nd Jul 2017 2:53pm |
That's what although badly I was trying to say Stan. I just wanted to keep the revs up a bit as I only have about 15 mns on the motorway then A roads. Easier to do it on the motorway. Current: TDV8 (3.6) RRS HSE
22nd Jul 2017 2:57pm |
here's an extract from the WM explaining how the dpf works,
22nd Jul 2017 3:04pm |
