![]() | Home > Maintenance & Mods (L322) > 4.4 TDV8 Turbo Twin Oil Drain Pipe Modification - DIY? |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
I'd say unless you are VERY competent mechanic with all the correct quality equipment this is one job too far.
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 960
TBH I'm less concerned about drilling & tapping the thread for the additional drain tube to screw into, its an alloy sump so aside from catching / removing all the swarf (which is also covered in the TB) shouldn't pose a problem. Its the stripping down to get that point I'd be keen to hear if ayones tackled. |
| mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912
I'm sure i've read many a post about removing the front subframe for welding on older cars, so a search my reveal what you are looking for.
| Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1482
Are you thinking of this because you have a problem now or just as a preventative.
It's in relation to a potential purchase (not yet road tested) and working on the basis it hasn't had the modification completed, I'm factoring in the cost depending on if realistically achievable at home (consensus seems that it's not) versus using an indy or MD. £1k to £1.5k?
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786
Pretty sure mine has t had it done before I owned it. Spirited driving and getting the revs over 2700 regularly seems to keep the symptoms away.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
I would definitely get it done, MD or Indy, but preferably by someone who has done one before.
Hmm, mixed opinion then! - does anyone have any actual examples of total cost / where it was carried out? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i believe its around £1k..... ... - .- -.
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
Mine was £950 15 months ago at at Team Valley Landrover, an independent in Newcastle |
Thanks Cass, I was assuming around the £1k mark so that confirms what I should be expecting to pay, if required.
| Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409
I suspect this oil burn can contribute to a premature death of the DPF. |
| mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104
Hi, I got it done on my 2012 by the one and only authorized dealer/service in Budapest. During the procedure I was permanently around with the bulletin in hand and asking for step-by-step conpliance. Although they managed to convince me that removing of the front subframe is not necessary. And actually they could complete the job very nice and tidy without SFrame removal. Witnessing all the activity I would not judge this task as too complicated, or calling for huge expertese. Only thing required is patience, and slow drilling, with grease on the bit to remove metalic particles. And of course you need the kit. 4.4 TDV8 Vogue Buckingham Blue MY12
Well I went ahead & bought the car yesterday (2011 4.4 TDV8 Autobiography, black with ivory) and was unable to confirm if the new drain pipe had been fitted by looking from under the front right wheel arch area up into what yo can see of the engine block / sump and nothing in the comprehensive paperwork, I'll crawl under again today armed with a telescopic mirror / torch to definitely confirm.
