![]() | Home > Maintenance & Mods (L322) > 3.6 turbo replacement |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Im sure i read a thread where one of the mechanics on here replaced one at the side of the road and think you can get to one through the wheel arch but dont know how easy it would be! Not much help really! Current 2007 TDV8 Vogue Buckingham Blue |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
UK drivers side id quite easy to get to, the other side is another story!!! NOT for the faint hearted! |
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Not faint hearted , just wondering if it was a reasonable prospect , |
Dropping subframes, dropping front diff... Pretty hardcore for a driveway job! |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1848 ![]() ![]() |
Turbo comes off with manifold
Thanks for the heads up , time won’t be an issue I’ll just take it steady , may have to wait for a improvement in the temperature though as it’s a bit chilly at the moment, cheers |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Sorry to here about your L322.
148000 miles (2008 plate)
Thanks for the feedback.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
The bearing is white metal and in theory should have an infinite life span.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Just my experience , my 2007 had 140k miles on it, oil changed every 8 to 10k kilometres and was like new at every change. Left hand turbo snapped its shaft, luckily the snapped part fell into exhaust. I stopped the car due to amount of white smoke and had both.turbos replaced and all good. My indie dropped engine to change turbos. 2015 4.4 AB
Thanks gents. Interesting feedback. I keep wondering whether to buy spare turbos now while I have the cash. I’m sure I won’t if it happens down the track. Mine has 275,000km or 170,000miles. ______________________________
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Diff and subframe didn't come off on mine im sure and i saw him daily but he did struggle getting a few bolts in though.I also covered the oil lines with a heat wrap as they run close to the turbos and was told can affect the oil feed to them.
Got the exhaust disconnected and the drivers side (right) one is full of oil the other one is dry , struggling to get the top bolts which connect the turbo to the manifold .
