![]() | Home > In Car Electronics (L322) > Blown speaker, bit of advice? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
I found the nuts holding the bass speaker were loose allowing the whole thing to vibrate. Tightened up the nuts, never been a problem since. Could be worth a try. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35780 ![]() ![]() |
panel off , see if it vibrates.....
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Thx Nicedayforit, a great shout.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
It may be obvious, however it may well be something in the coil.
Had a poke and found it's not the pillar speaker, it's the sub.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
That would suggest a loose mounting somewhere I would have thought Current: 2011 FFRR Vogue SE 4.4 TDV8
Yes sure Bushy makes sense and I found this is the WM which is basic but a sensible starting point:
