Home > In Car Electronics (L322) > Blown speaker, bit of advice?
GGDR
Hi guys, I think I may have blown a speaker, I am hearing a 'rattle' instead of thump thump thumping bass.
I have the premium HD HK, it's the NS rear pillar speaker, numbered 8 on this pic. The 1200w ICE is epic and I must admit I do give it a workout.
I wondered if the trim panel is vibrating. I have fitted a rear cam and whilst I haven't removed that trim panel, I did lift the tailgate rubber, pull that panel back a bit and then fed the dash cam cable in there. But I checked with the speaker pumping and the when I hold/grip the trim panel in various places, it doesn't seem to be the cause.
If I remove the speaker, any tips to look for?
I wondered if I should swap the two 8's - perhaps that will tell me amp vs speaker?
Any tips most welcome.
. Cheers, Greg
Post #498276 12th Dec 2018 10:24am
I found the nuts holding the bass speaker were loose allowing the whole thing to vibrate. Tightened up the nuts, never been a problem since. Could be worth a try. Thumbs Up
Post #498278 12th Dec 2018 10:40am
panel off , see if it vibrates.....
if it still vibrates , disconnect speaker and see if that solves it.....
if it does , put ''new speaker' on your xmas list..
Wink
Post #498280 12th Dec 2018 10:42am
GGDR
Thx Nicedayforit, a great shout.
Stan I'm scared to ask Santa (aka Duckworth Dan) how much for one of those....
Yes I'll get that panel off, was just mainly wondering once I've got the speaker in hand what to look for.... Cheers, Greg
Post #498296 12th Dec 2018 1:33pm
It may be obvious, however it may well be something in the coil.
I had a house speaker blow once. Looked perfect, made a god awful racket! My front Ps door speaker has developed a bit of a rattle at high vols. can’t be bothered to take the panel off!! Turned it down a bit. There is nothing that can't be fixed with a hammer😜😜
Post #498387 12th Dec 2018 11:43pm
GGDR
Had a poke and found it's not the pillar speaker, it's the sub.
Looks pretty buried behind the trim, just forward of the NS internal access panel.
I can get my hand in there and feel the speaker.
Wondering what the rest of the black box contains, it's massive. (No. 10 on the above diagram)
Having a feel around the speaker I can deaden and even eliminate the popping sound with my hand with a bass-y track playing.
Any sub woofer experts out there?
Wondering what I need to check for I guess....
Thanks, Greg
. Cheers, Greg
Post #498552 14th Dec 2018 10:41am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
That would suggest a loose mounting somewhere I would have thought Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #498553 14th Dec 2018 10:45am
GGDR
Yes sure Bushy makes sense and I found this is the WM which is basic but a sensible starting point:
. Cheers, Greg
Post #498554 14th Dec 2018 10:47am
