Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Eac 11 Member Since: 15 Feb 2019 Location: Cheshire Posts: 4 |
gonna_go_double_r
15th Feb 2019 9:32pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Hi Eac11, sadly I've not succeeded with my experimental fitting of the Ford Mustang unit.
16th Feb 2019 3:37pm |
gonna_go_double_r
18th Feb 2019 11:55pm |
I got this from Dan, but you can check microcat for the actual PN's
19th Feb 2019 12:27am |
iainvr4 Member Since: 16 Mar 2013 Location: glasgow Posts: 8 |
How do you get the back of the seat to come off? Are they attached by screws or clips? |
22nd Feb 2019 3:30pm |
Markbhai Member Since: 05 Jul 2015 Location: bradford Posts: 20 |
I Have just fixed this on mine, mine was the fan assembly in the back of the seat, the part was around £125 and I got my local garage to change it for me. |
24th Feb 2019 8:46pm |
I know it's late but thanks for your help gonna_go_double_r
14th Jul 2019 11:48pm |
What fan unit did you buy if you don't mind me asking for £ 125 as I recalled the genuine part being more like £250. Just for future reference. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4226 |
Some pointers please....seat base cooling works but not seat back...
10th Aug 2019 1:21pm |
Yes could be ducting. The units are more likely to fail in heat mode.
10th Aug 2019 1:36pm |
Thanks.
10th Aug 2019 1:43pm |
So, it heats both base and back but only cools base... Thoughts? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 on order so "Rory" will be going to a new home....! 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
13th Aug 2019 4:37pm |
Could be duct, get the back off the seat (bit of a phaff) and inspect the unit to start Rob.
13th Aug 2019 4:58pm |
Will do. Looks like seat back can be removed by carefully following the instructions here. As ever, very helpful 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Aug 2019 9:53pm |
