![]() | Home > Technical (L322) > 2010 Heated/Cooled Seat not working |
Eac 11 Member Since: 15 Feb 2019 Location: Cheshire Posts: 4 ![]() ![]() ![]() |
gonna_go_double_r
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Hi Eac11, sadly I've not succeeded with my experimental fitting of the Ford Mustang unit.
gonna_go_double_r
I got this from Dan, but you can check microcat for the actual PN's
iainvr4 Member Since: 16 Mar 2013 Location: glasgow Posts: 49 ![]() ![]() |
How do you get the back of the seat to come off? Are they attached by screws or clips? |
Markbhai Member Since: 05 Jul 2015 Location: bradford Posts: 20 ![]() ![]() ![]() |
I Have just fixed this on mine, mine was the fan assembly in the back of the seat, the part was around £125 and I got my local garage to change it for me. |
I know it's late but thanks for your help gonna_go_double_r
What fan unit did you buy if you don't mind me asking for £ 125 as I recalled the genuine part being more like £250. Just for future reference. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
Some pointers please....seat base cooling works but not seat back...
Yes could be ducting. The units are more likely to fail in heat mode.
Thanks.
So, it heats both base and back but only cools base... ![]() Thoughts? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
Could be duct, get the back off the seat (bit of a phaff) and inspect the unit to start Rob.
Will do. Looks like seat back can be removed by carefully following the instructions here. As ever, very helpful |
