Home > Technical (L322) > L322 4.4 TDV8 faulty oil level sensor
Baltic Blue
https://www.fullfatrr.com/forum/topic46960...oil+sensor
I’ve found this post, but it’s an L405 v6, but it finishes by saying the 4.4 sensor is easy because it is external.
Cost c£70 ?
Post #504862 11th Feb 2019 8:43pm
rjff
If this helps, dash message with cold engine and bonnet shut and working level indicator.
Also, if your battery is getting wet, there is a scuttle drain pipe which should be fitted to the bottom of the drain, indicated with a yellow circle. This takes water away from the batttery. Also perhaps seals around engine bay leaking in that area.
 Cheers
Richard
TDV8 Vogue (11MY)
Gap IIDBT (learning but happy to help)
Post #504897 12th Feb 2019 12:02pm
rjff
Pic of sensor location, obviously upside down
Just caught your other thread, and I think Mike's (Baltic Blue) and Stan's ideas of fuses and voltage should be your first port of call.
If your battery is getting wet, a thorough clean of all contcts/connectors in that area may help. These beasties are easy prey for electrical gremlins. Cheers
Richard
TDV8 Vogue (11MY)
Post #504914 12th Feb 2019 4:00pm
Baltic Blue
Thanks rjff that is the picture I was looking at last night but was unable to post because I am using an internet connection so slow I think it must be via carrier pigeon,
but now other symptoms are being discussed like temperature sensor, wet battery.... it’s time to get the AVO out and the wiring diagram. Bow down
Post #504916 12th Feb 2019 4:20pm
rjff
Ahh Mike
Another man with an AVO Bow down Thumbs Up
I tried rotating the image of that sensor, wow, it looks just like those always ascending stairs. Cheers
Richard
TDV8 Vogue (11MY)
Post #504917 12th Feb 2019 4:39pm
edward19
A big thanks to everyone for helping me. The pictures and suggestions are a great help. With regards to the water leak the drain channel in the top right hand corner, adjacent to the wing is unblocked. However when it rains, the water runs over the top of the gully in the trim and onto the battery. Any suggestions on how to remove would be great.
Post #504918 12th Feb 2019 4:40pm
rjff
Edward
In my photo you can just see the drain tube in the dark recesses of the battery compartment. Make sure that is properly connected to the bottom of the drain fitting circled and is not blocked somewhere along it length. Mine was, and let the water build up until it overflowed onto the battery. I used a strimmer cable as you would a drain rod. Worth checking the driver's side too. Cheers
Richard
TDV8 Vogue (11MY)
Post #504919 12th Feb 2019 4:47pm
Baltic Blue
rjff... my dad bought me an AVO 8 as a gift for passing my C&G full tech, and it is still in regular use nearly 50 years on.
Best meter ever... Thumbs Up
Post #504920 12th Feb 2019 4:51pm
rjff
Mike Thumbs Up
Edward, let us know how you get on, and if we can help further we will. Cheers
Richard
TDV8 Vogue (11MY)
Post #504921 12th Feb 2019 5:12pm
edward19
I sure will. At the moment it doesn't run!!. However I did buy it like that. Don't ask!
Post #504923 12th Feb 2019 5:22pm
Site Copyright © 2006-2019 Futuranet Ltd & Martin Lewis
