![]() | Home > Technical (L322) > L322 4.4 TDV8 faulty oil level sensor |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
The tube you can see on the LHS is the oil extraction pipe, for changing the oil.
edward19 Member Since: 11 Feb 2019 Location: South Coast Posts: 55 ![]() ![]() ![]() |
Hi Mike
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Unfortunately no, i try that some time ago as a way to check electronic oil level accuracy, but it did not work. if I remember rightly replacing oil level sensor is mayor undertaking |
Thanks and what a nightmare that will be. I'm thinking about draining the oil through the extraction tube and measuring how much is in there. Ridiculous!!. However do you think it could be possible to remove the extraction tube and replace with the 3.6 TDV8 dipstick. Presumably the sump outlets will be different? Did you try this?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35857 ![]() ![]() |
the 3.6 and 4.4 are different engines so if you did stick a dipstick in the 4.4 how long does it have to be...to many variables to do that me thinks..
Hi
I am not aware of anyone having to change one, but the picture in the workshop Manual shows it being external to the sump and bolted upwards ,
you could try checking fuse F20 in the engine bay fuse box and see if its blown... |
Many thanks. I will try the fuse and take a look underneath. Where you say bolt upwards, does it look like the bolt is on the outside of the sump?
Yes, it looks like 3 bolts. G reg 2.5VM Vogue Portofino red 1991- 1999
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Suggest, just to eliminate gremlins as a cause, doing a battery reset.
Thanks
When did you get the error on-screen?
Hi
