Home > Technical (L322) > L322 4.4 TDV8 faulty oil level sensor
Page 3 of 3 <123
rjff
Evening Edward
The only little difference I can see is that the seal on the wing of your car seems slightly further towards the windscreen than mine and may not be sitting fully on the raised joint of the wing and inner panel. Could that make such a difference, I'm not sure? They certainly don't touch each other as you may think to seal.
You may be right in suggesting the seals are not compliant, mine are also knackered towards the front.
I'm at a loss at the moment to suggest further ideas. Either lots of others are keeping quiet 'cos they can't solve this, or someone on here will pop along and make us seem Embarassed
Grabbing at ideas, what about putting some waterproof tape between the two seals and seeing if that fixes the leak?
If I think of anything else I'll put it up, but don't hold your breath Smile Cheers
Richard
Gap IIDBT
Post #506057 22nd Feb 2019 7:13pm
edward19
Hi Richard
I've looked further at this blasted leak and believe the front windscreen plastic cowling is the primary cause of the leak. It doesn't fit flush against the screen in places and I'm going to sealant it against the screen. I'm sure I had to do this on a P38 once.
Thanks
Post #507187 3rd Mar 2019 7:29pm
edward19
Hi All
All sorted now as the oil level sensor is suddenly working and I have no more water leaks onto the battery. I also used the F type connector to repair my broken plastic coolant pipe. That was a great tip. Once I've sorted out the pulley problem I'm up and running.
Thanks
Post #507358 4th Mar 2019 8:51pm
rjff
Well done Thumbs Up
And thanks for letting us know. Cheers
Richard
Gap IIDBT
Post #507361 4th Mar 2019 9:05pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Can someone tell me where the oil drain pipe is, that was mentioned please?
It’s so much easier to pump the majority of the oil out first. When doing a change.
Post #507613 6th Mar 2019 3:12pm
Baltic Blue
Just remove the plastic cap.
Post #507621 6th Mar 2019 3:33pm
edward19
Slight confession in that the f type connector has started leaking. What a pain, so I've bitten the bullet and ordered a replacement hose. However does anyone know the best process for draining the coolant on the 4.4 tdv8? Any tips would be great. Also I got a rather weird ticking noise from the Top left hand side of the engine (off side) for a bit when cold. It went away and might be a screw rattling that I lost when putting the new idler pulley in!!!
Thanks
Post #507847 7th Mar 2019 7:09pm
Xpand1t
United Kingdom 2010 Range Rover SE TDV8 Zambezi Silver
Hi did you ever replace the oil sensor or find the reason why you were getting this fault message,
I am to getting the same message and i also had a high pressure fuel pump replaced wondering if there's a connection i have 2012 l322 4.4tdv8, appreciate your post was a few years ago...
Post #715648 6th Apr 2025 11:19am
Page 3 of 3 <123
